Results 1 to 20 of 20
'06 SV650 incredibly hard to shift
    So since day 1 the transmission on the race bike has been very hard to shift. Changing the oil helped a little, but it still gave me one helluva sore on my toe, enough that I had to double bandage and tape my toe... AND put a piece of card board inside my boot in order to shift w/o being in pain
    It's a LITTLE tough to shift just putting around the paddocks, but it's no where as difficult as it is when I'm at speed.
    Any thoughts? Hope it's something simple. Gotta get my hands on a service manual.
    Lifer NobodySpecific's Avatar
    Apr 2008
    Burlington, VT
    Re: '06 SV650 incredibly hard to shift
    I've got the SV manuals in PDF format. I'm not sure if most e-mail accounts can handle them (kinda big) but if you want I can try and send them to you. They are also available on The Pirate Bay for download (you just need a torrent app) The Pirate Bay - The world's largest BitTorrent tracker It's not illegal, they just didn't have the server capabilities to handle all of the downloads. I'm not sure how well it is seeded, which is why I offered to e-mail them.
    Also, have you adjusted the clutch as described here:
    FAQ: How do I adust my clutch? AndyAuger's Clutch Mantra - SVRider Board
    Some kind of tube RupturedDust's Avatar
    That's definitely not right. When you squeeze the clutch, do you feel the engine disengage? If nont, it's probably your clutch needs adjustment. If so, then it's a problem IN the transmission, most likely. My first step would be to look and see if the shift shaft that goes into the transmission is bent. Any idea if the bike has been down on that side?
    Enjoy life! There's plenty of time to be dead.
    2002 Suzuki SV650 Nekkid
    http://www.squidbusters.com
    Well, you got the bike from Hobbs, what do they have to say about it? Was it that bad when they were using it?
    Apr 2006
    Beverly, MA
    Hard shifting on an SV is usually indicative of a clutch lever that needs to be adjusted. It's a pretty simple procedure, and has been outlined on svrider.com many times.
    P.S. You've got PM.
    Sounds similar to a bent shift shaft in the engine on a Hawk.
    Foxboro, MA
    Quote Originally Posted by schleppy View Post
    P.S. You've got PM.
    he's racing so he only uses the clutch lever when he's downshifting
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Dr Q : Last resort Medic Qfactor's Avatar
    Homeless, MA
    I would check the parts diagrams and pdf fiches for the shifter rod assys (the ones that go into the cases.
    I would be willing to bet there's a bearing (or bushing) that's getting old or really dry...
    Oreo - Have you tried spraying some lube on where the shifter rod goes into the cases?
    try it and see if it gets little better...
    Q
    Northshore/Beverly, MA
    With the engine off, and spinning the rear wheel, does it shift up/down OK?
    If it does, clutch pack sticking, or bent clutch rod, or rod out of adjustment. (adjustment at rod side not handle side). I'm sure they have an adjustment...
    Just Registered Doc's Avatar
    Jericho, VT
    I am gonna go with Gino.
    Worcester, MA
    LRRS EX #165 (formerly)
    Clutch lever & cable is adjusted just fine.
    Schleppy, thanks in advance for the manual
    Mark, you gonna be around at all this weekend? Gonna try & tear into it.
    Pete, Airshow at Westover on Saturday...
    Sunday should be clear....I'm gonna be at Degsy's on Friday afternoon, and have to fit TJ in too.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Posted by Jane in BoxChat
    it's part #18 and #19 that sets up the adjustment first, then you set the cable slack at the clutch lever. Many miss this!
    Pete, still got some moving cleaning up to do, but I bet I could hit you after work on Thursday...if it's just the rod adjustment, you are out of it in 15-20 minutes...
    Apr 2008
    Burlington, VT
    The link I provided addresses this and gives a procedure for doing this on the SV
    Quote Originally Posted by SV650N View Post
    Sorry, didn't read the link, because this is the 1st thing you look for.
    If the arm doesn't rotate enough, and the rod is too far back, it won't engage the clutch enough to release the plates, and will still put tension on the drive dogs. If the clutch plates and steels are warped, or the screws that hold the pack together are bent will also cause an issue at high rpm's.
    I do this in my sleep...
    adjust shift linkage so that the linkage rod is perpendicular to the shift arm (you may have to reorient the shift arm on the splines ) for best leverage, make sure linkage is tight, clean & lubed, not sloppy, it it is, replace it
    Lifer akira700's Avatar
    Apr 2005
    in the city
    Quote Originally Posted by BMFR6 View Post
    EVO Shift STAR Kit benefits?
    Easier upshifts under hard use.
    Effortless downshifting
    Driving in flip-flops? The STAR is a "must have!
    Pete, this is for you then!
    2008 Honda CBR 600RR
  1. shift rod on 2006-ish sv650 rearsets?
    By caboteria in forum Woodcraft
    Last Post: 08-09-17, 05:12 AM
  2. SV650 hard starting
    Last Post: 01-21-14, 08:59 AM
  3. 2nd gen SV650 SPEARS shift star and linkage arm
    By catahoulabuldog in forum For Sale
    Last Post: 10-15-13, 10:22 AM
  4. Vortex shift bracket SV650
    By KB in forum Pit Area
    Last Post: 03-20-09, 06:01 PM
  5. Wanted: 2006 SV650 shift lever
    By schleppy in forum For Sale
    Last Post: 05-11-08, 10:16 PM
