Results 1 to 9 of 9
Engine Compression Range?
    Senior Member kumpy's Avatar
    May 2012
    Norton MA
    Just wondering what is consider healthy and normal for regular street bikes and for race bike with high compression.
    2000 R6 regular gas
    Cylinder 1: 176
    Cylinder 2: 155
    Cylinder 3: 175
    Cylinder 4: 156
    2002 GSX-R750 high compression is averaging about 170-180 for all 4 cylinders but I can't remember exact numbers.
    Apr 2011
    NH
    Re: Engine Compression Range?
    Not sure of specs for your bike but as a general rule, 10 percent difference is ok, using your high that would be 17-18psi. You're a bit over that. I would not pull the motor apart for just that. Is there a reason you checked the compression? high mileage, lots of laps, burning oil, etc.
    How do the plugs look?
    Tim
    LRRS #44
    Superbike Services 44
    Wirelessly posted
    Lol. He saw me do it and likes to fiddle and worry.
    Lol. Love you kumpy!
    Wirelessly posted
    Are all spark plugs out? Are you holding the throttle WFO?
    Are your valves in spec?
    Lifer Stromper's Avatar
    Eastern Ct
    Do not seek what you fear to find
    Was it warm ?
    Tight valves
    Old squirt of oil trick
    The calculus of hate
    May 2012
    Norton MA
    Wirelessly posted
    All the plugs are out and held the throttle WFO just like you taught me!
    Not sure if my valves are in spec, how do you check that?
    May 2012
    Norton MA
    Quote Originally Posted by timmyho414 View Post
    Plugs look dry, dark brown. Seemed to be normal looking. Reason I checked the compression was cause it has 12k miles, I got it used which there's always a concern, lots of laps through it, about 12 track days this year. I wanted to find out what kind of condition the motor is in. what are the reasons why people do compression tests?
    Derry NH
    Usually you do compression tests if you have a problem with misfires that isn't spark related, or are consuming oil/coolant at an abnormal rate. These issues could indicate a bad head gasket or rings, which are more easily found with a compression and/or leakdown test.
  1. Compression Tester
    By Tekime in forum Bike Maintenance
    Last Post: 02-27-19, 07:59 PM
  2. Compression Test
    By Garrett in forum Bike Maintenance
    Last Post: 04-22-14, 10:06 AM
  3. No compression...CR125
    By sdog30 in forum Dirty Bastards
    Last Post: 08-10-11, 09:59 PM
  4. Anyone know a lot about compression release ?
    By danny86 in forum Dirty Bastards
    Last Post: 06-13-09, 05:28 AM
  5. Compression tester
    Last Post: 08-13-03, 09:00 AM
