Results 1 to 10 of 10
08 sv650 help
    Feb 2016
    Somerville, MA
    08 sv650 help
    Bike was in storage for 2 months while I was on a trip. Went to start the bike today and turned over, stays running for a couple seconds then dies.
    Battery was tested and passed.
    I hear the fuel pump prime.
    Fuel only sat for 2 months in tank.
    Is it my fuel pump pressure? Spark plugs?Anyone have any suggestions? I don't want to start going crazy without consulting someone who may have had a similar issue first.
    Lifer Imbeek's Avatar
    Sep 2012
    Southwick,MA
    Re: 08 sv650 help
    Check the airbox for nests
    Senior Member TwelveGaugeSage's Avatar
    May 2017
    Palmer, MA
    Re: 08 sv650 help
    Have you tried running it with the gas tank opened?
    Feb 2016
    Somerville, MA
    Re: 08 sv650 help
    No nests. Will try it with the gas cap open when I get home today.
    Feb 2016
    Somerville, MA
    Re: 08 sv650 help
    No luck with gas cap open
    Re: 08 sv650 help
    Did you stabilize the fuel before you put it in storage? And how full was the tank with gas before storage?
    Re: 08 sv650 help
    so it starts every time and then dies after? or it did that once and how wont start but turns over? you said the battery was good how many volts? is there an inline gas filter? mice like exhausts as well as air boxes make sure its clear.
    I would drain the gas put fresh in and change any filters.. check the above and report good luck
    Feb 2016
    Somerville, MA
    Re: 08 sv650 help
    Where can I dispose of gas? It was only in storage for 2 months and gas looks clean... no lumps. It I will swap it out and look at exhaust, lines, and filters
    Re: 08 sv650 help
    Quote Originally Posted by Mikesalt13 View Post
    You wouldn't see lumps. The ethanol attracts water, so your engine would be trying to burn water. Happened to my sisters bike years ago, which was carbed. Never heard of problems with fuel injected bikes for the most part though.
    Nov 2009
    Bristol County
    Re: 08 sv650 help
    Put it in a car with a mostly full tank.
    Cars can handle some amount of water. It's an old method to clean the chamber is to mist water instead of Seafoam down the intake. Steam cleans the insides. Just dilute it with enough good gas.
    nedirtriders.com
