Results 1 to 10 of 10
190 rear for the R6
    Member JenzR6's Avatar
    Mass
    190 rear for the R6
    OK got a question I talked to R7 about running a 190 for a rear versus the stock 180 he said should be ok.. Than i post the same question in a R6 forum and one of the kids had this for a reply
    I would be more concerned about tire/chain clearance, it is damn
    little on a 180! The 190 is, of course, 10 mm wider or .4", or .2"
    (almost 1/4") closer to the chain, too close for MY comfort. Once the
    chain has ground off the extra rubber you're good to go!!
    How can I check this to see if I am good to go or not ???
    Thanks in advance Jen
    190 rear for the R6
    why do you want to go to a 190? wouldn't it make the bike turn slower and have a heavier feel?
    Mass
    190 rear for the R6
    chip got the tire for me for pretty much nothing I didn't want the 190 but for a free tire to burn off I mean have for the season I wasn't complaining
    Hey did you see that cop RevHappy's Avatar
    New Hampshire
    190 rear for the R6
    Jen it wont fit, I tried to do a 190 on my old R6 for the dragstrip.....Saaaawwwieeee
    190 rear for the R6
    I've seen R6's with 190's on them, they do fit. Eric from the Vt rides, had a blue 99 R6, he had a 190 on his. Yes, the 190 is 10mm wider than a 180 but it is also going on a rim that is 13mm narrower than what it should be on. It won't "look" any wider than the 180 You can check fairly easily if it will fit, messure the distance between your chain and the tire you have on now, if you have more than 5mm (half of the 10mm size differance) it shouldn't be a problem. But again, the 190 won't actually be 10mm wider on your R6 rim. Follow?
    190 rear for the R6
    Oh, and for tire to chain clearance? My R7 has less than 1/8th inch between the tire and chain and i have had no problems. I also upgraded to a 190 from a 180 on the R7 but it has a 6.25" rear rim.
    Mass
    190 rear for the R6
    OHH man well my new chain is only a 520 I guess I gotta show this to chip and let him figure out the math I just ride it... and he put in a new sprocket combo and new chain so I can only guess what my bike is going to feel like with all the changes...But, thanks for all the imput I will let ya know how I make out :cool
    Lifer GadgettR1's Avatar
    New Bedford, Ma
    190 rear for the R6
    OHHH boy.. sounds like I got some measuring to do... oh well if it doesn't fit it just means I got another tire to go on my "spare burn em up rim" WOOOOO HOOOO
    Mass
    190 rear for the R6
    UMMM that means I can burn yours off and leave my bike off the burnout bored so I won't have to pick the rubber off the undertails for weeks later
    New Hampshire
    190 rear for the R6
    I duh no? Maybe it didnt fit because I had a 520 conv. with 2 up in the rear????
  1. For Sale - Parts & Tools | 03-04 ZX-6R rear Rim - $100
    By hondarider102 in forum For Sale
    Last Post: 07-09-15, 08:26 AM
  2. WTB Rear Take Off 180/55 ZR 17
    By jtryz in forum Wanted
    Last Post: 05-24-12, 08:01 PM
  3. rear brake pedal/rear light not working
    By seth399 in forum Bike Maintenance
    Last Post: 04-10-08, 09:57 PM
  4. PP 150 Rear
    Last Post: 08-27-07, 02:18 PM
  5. wtb kx 60 rear rim
    By SQUIZZ636 in forum For Sale
    Last Post: 05-21-07, 07:37 PM
