Results 1 to 7 of 7
2000 yz250 front brake - won't hold pressure
    took a tip coasting down a hill and bopped the master cylinder...since then, when you grab the front brake, there is no pressure.
    If you pump the lever a few times, it will build pressure and hold it, but if you let the lever go about halfway, all the pressure is released.
    I unbolted both of the banjo bolts, emptied/cleaned the master cylinder, used a vacuum pump to pull fresh fluid through the system, but it's still the same...
    google doesn't match my specific scenario, so the only thing I can guess is a seal with the plunger in the master cylinder popped when I fell...I either need to rebuild it, or start replacing pieces (brake lines and/or calipers) until it sorts out
    anyone experience this or have an idea of how I can fix my current system?
    Member dougie's Avatar
    Jul 2013
    Groveland, Ma
    Re: 2000 yz250 front brake - won't hold pressure
    Rotor straight? If it got dinged it will push the pads apart as it rotates and you will need to double pump the lever to feel anything
    LRRS EX #473
    Thanks to my 2017 sponsors: Dunlop, Sidi, Woodcraft, Bell
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    One time I had a similar issue. I put on a new master cylinder after a crash. Would not pump up correctly. Fiddled & diddled. Finally I removed the lever and used a rod and pushed in the piston a few times and held it in and let the air out. I repeated a couple times and I replaced the lever and was good to go.
    I have a master off a WR450 in mint shape for sale.......
    You need to replace it with a radial master from a GSXR.
    2016 BMW S1000XR
    Quote Originally Posted by dougie View Post
    rotor straight...the double pump is required at a stop or move and independent of rotor position - but good to know!
    hmmm...I am also suspecting the master cylinder...but unfortunately I'd say mine was busted up when I tipped over. I've seen rebuild kits, but I'm not sure if I broke the mater itself, and not the parts that are replaced in a rebuild...
    ordered another master cylinder...should be here Monday
    all good...found another one, thanks!
    was just the master...swapped it out and good to go!
  1. 2000 YZ250
    Last Post: 06-04-14, 08:30 PM
  2. Front brake lever microswitch + brake bleeding
    Last Post: 05-05-11, 07:52 AM
  3. 2000 YZ250 Ready to rock
    Last Post: 04-06-08, 09:23 AM
  4. Replies: 5
    Last Post: 10-29-03, 11:07 AM
