Results 1 to 5 of 5
2001 Honda 600 f4i problems
    Newbie
    Jun 2012
    Lynn MA
    I got more problems then I can handle the bike will charge for 24 hours ride for 3 days then dead battery is new and good and now yesterday Its not priming looking for a mechanic to come out to fix or it even a recommendation for a good shop in the area that's not gonn totally rape me
    Jan 2009
    Middletown, Ct.
    Re: 2001 Honda 600 f4i problems
    Sounds like your regulator/rectifier (most likely) or possibly the stator went.
    Regulator/Rectifier.
    http://www.ebay.com/itm/RICKS-VOLTAG...6e3b5f&vxp=mtr
    Stator.
    http://www.ebay.com/itm/Ricks-Motors...940799&vxp=mtr
    Both are pretty normal in the motorcycle world. There are ways to test them using a multimeter, a service manual can walk you through the whole thing. If you were closer I'd have a look for you but, uh, yeah.
    Newbie
    Jun 2012
    Lynn MA
    Thanks a lot it looks like the regulator won't. Be that hard to put in and it's cheap I'f it Ends up being the stator how hard is that to install
    Jan 2009
    Middletown, Ct.
    Pretty simple as well, drain the oil. Pull the cover (about 8 bolts), 3-5 bolts hold the stator into the cover and then trace the wires to the plug. When pulling the cover you may trash the gasket. So to be safe I'd grab one before you do the job.
    martyk martyk's Avatar
    canton ma
    you can also use the gasket maker crap that comes in a tube, i did that when i replaced my oil pan. its the black, oil resistant kind. worked great for me. but yes regulator/rectifier seems the culprit. you can also check this sort of by checking the charge in your battery. either take the battery to an advanced auto store or if you have a multimeter you can check, if battery reads dead or a bit lower then 12 then its a charging issue
  1. For Sale - Motorcycles | 2001 Honda XR100
    By theducman in forum For Sale
    Last Post: 08-12-19, 07:00 PM
  2. 2001 TTR 125 PROBLEMS PLEASE HELP
    By mikesttr125 in forum Bike Maintenance
    Last Post: 08-11-12, 08:52 PM
  3. 2001 Honda VFR 800
    Last Post: 08-17-07, 01:15 PM
  4. Honda 1986 XL 250R Problems
    By theothersean in forum Bike Maintenance
    Last Post: 05-12-02, 08:37 PM
  5. 1986 Honda XL 250R problems
    By theothersean in forum General Bike Related
