So, last season I was having some strangeness with the track macheen...
It starts right up no problem when it's cold. If I go out and run a solid 20-minute session and the bike gets good and hot it won't start if I shut it off and immediately try to restart it. Bump starts no problem. If I let it cool for 50-60 minutes it starts right back up.
When it doesn't start, it feels like a dead battery. The starter tries to turn the motor over, but generally only gets through one or two cranks with a decreasing amount of power per "crank."
I bought a new Yuasa battery when I bought the bike a few years back (2009?), so it's possible that the battery is farkled. I did swap it with the Yuasa that came with the bike and had the same issue when it got hot. I happened to have a spare starter motor on the shelf so I swapped that out and voila... The problem went away for the second half of last season. On Monday the problem is back. I should probably buy another battery, but does anyone have any ideas here? I may also replace all of the battery to starter wiring with new 4-ga stuff. Any idears?
Thanxxxooxxxoo
_trickery
