Results 1 to 18 of 18
636 won't start
    Senior Member apollomx681's Avatar
    636 won't start
    I've tried everything I can think of so far. I washed the bike the other day and i started it up and rode it about 200 yards and it bogged and died and then would not start. at first i thought i was out of gas. so i filled it up with 93 (didn't think of it at the time but maybe water got in the tank? but filling it would of diluted it..?) so eventually i got it home. i check all the fuses, and all the connections. those are all good. i drained and emptied the tank and then filled it up with fresh gas. i check the air filter and that all looks good. it wont bump start and I've been trying to figure out how to do a self diagnosis but cant figure it out. the battery is good. the feul pump primes and it makes all the right noises and everything. I'm thinking either the fuel pump is dead, or all 4 plugs are fouled which i know is very highly unlikely. does anyone have any input on some other ideas or comments?
    LRRS- zip-tie alley #681
    2004 zx636r- road....carbon fiber=
    2002 sv650- toecutter, track
    2002 xr100- dirty play
    Re: 636 won't start
    yea it tries and tries to crank but wont fire over..
    .... duey's Avatar
    Wilmington MA
    Re: 636 won't start
    check for spark.
    2021 Ducati Panigale V2
    2020 Honda Grom
    Re: 636 won't start
    yea i gotta go get my socket plug tomorrow and then that is the next thing i'm gonna check
    Re: 636 won't start
    maybe some carbon fiber got into the motor
    do you need a spark plug socket to check your plugs? i have a few of them in my toolbox
    Full Tilt - Full Time Trackday Guru's Avatar
    Dec 2006
    Concord, NH
    Re: 636 won't start
    You may also want to make sure your Bank Angle Sensor is in it's correct position. If not, all else will be normal but the bike won't start.
    Good Luck
    Mike
    Am #124
    Re: 636 won't start
    yeah i also checked the tip over sensor.. that seems to be good.. got this tip from wera.. im gonna try this next..
    "had the same problem with a 636 once... there was water in the tank but emptying and filling back up was not enough, had to unhook the fuel line from the rail and cycle the ignition on and off so the fuel pump would turn on... there was water still in the pump and fuel line... when you do this try to keep the fuel pump at the lowest point so that it will scavenge all of the water..."
    although i did try to repump it but it was still attachted to the tank...
    Lifer Pittenger5's Avatar
    Austin
    Re: 636 won't start
    Quote Originally Posted by apollomx681 View Post
    Dollar Bill agrees with this being the next course of action
    Zip Tie Alley #505
    Member madkaw's Avatar
    Nov 2006
    Pittston, PA
    Re: 636 won't start
    I might be talking out my butt here but at the risk of sounding like a fool here it goes. Maybe there's water sitting in the throttle bodies? I don't really know how water getting into the gas tank would affect them but I do know that when my F4(which was carbeurated) got water in the tank the bike would have a hard time starting and revving past 5K. I never had to drain the tank since water was heavier than gas and would just make its way down to the bottom into the carbs and into the bowls. But I would have to pull the carbs off, pull the bowls off and the main jets too, dry them with a compressor, and/or towel dry them, and let them sit and air dry overnight. That would always remedy the problem, but like I said, I don't know if this same problem and solution could happen with a fuel injected bike.
    My $.02
    Re: 636 won't start
    thanks db well you know what that means.. i need your feul pump if that doesn't work. if you come over tonight you can help me and i can buy you some JD if you want haha.. or juli can bring you some ice cream and brownies and maybe a sister too
    Austin
    Re: 636 won't start
    You can use your pump according to the wera board
    Zip Tie Alley #505
    Re: 636 won't start
    i know but im saying if that isnt it... but either way i want to do that. check plugs and tend the battery today. so i will end up grabbing those thigns from you after work if you want to meet up. just let me know!
    Austin
    Re: 636 won't start
    Yah, Im sure Ill pop out, worse comes to worse Ill just swing em in, good excuse to take a ride.
    Just call me or drop a text after work, I do forget things often. (I blame the drinking)
    Zip Tie Alley #505
    Re: 636 won't start
    sounds good to me and if it works, i believe we need to celebrate!
    Re: 636 won't start
    did you try kicking it?
    maybe swearing at it?
    or both at the same time?
    Just Registered drop's Avatar
    Bradford, MA
    Re: 636 won't start
    i fixed a jammed starter pinion on my outboard that way while floating about 200 yards from shore.
    kicking alone didn't work - i had to swear at it before it finally responded to additional kick attempts.
    Re: 636 won't start
    didnt kick it yet?
    but i gave it a verbal lashing like a bastard step child....
    still no worky.. i think its just really pissed off i bought an sv..
    Senior Member nerijusj's Avatar
    Somerville, MA
    Re: 636 won't start
    didnt kick it yet?
    Is the FI light on? If you checked everything and still can't find the problem, I'd try to see if/what codes your bike is throwing. You got a manual? It should describe how to pull codes out. I know on my 05 636, I only had to ground 1 connection under the seat, get the code and look it up for what it is.
    ZX10R
    Ned
  1. can't get it to start
    By ku996r in forum Bike Maintenance
    Last Post: 08-23-08, 06:51 PM
  2. Wed, 7/9, start in RI
    By jeantarrou in forum Rides & Events
    Last Post: 07-08-08, 07:49 AM
  3. start um up let um run
    By beet in forum Bike Maintenance
    Last Post: 12-17-03, 07:47 AM
