Results 1 to 12 of 12
ninja 2009 motor upgrades
    Silver Bullet Commuter fjrrider RI's Avatar
    Narragansett, RI
    Any suggestions on some items to up my torque or horse power on the Ninja 650 EX? I like the bike and riding position and I know it is not a raceing bike replica just wondering if I can up the punch with some add ons?
    Yamaha lover
    Wistah
    Re: ninja 2009 motor upgrades
    Full Muzzy system, DNA filter, PCIII with proper re-map, plug the PAIR valve, remove the airbox snorkels.
    But if you really want to go faster, throw on some Pirellis, swap the crap stock shock for a Penske, rebuild the forks (emulators, stiffer springs, preload adjusters, etc), and enjoy.
    Wait, what? Jonny Rocket's Avatar
    South Windsor, CT
    How much do you want to spend?
    Lifer ilikenapalm's Avatar
    Connecticut
    A treadmill.
    Isn't there a Big bore kit for that thing>>>>?????LOLOLOLOL
    Narragansett, RI
    Quote Originally Posted by KawiSmurf View Post
    Can I just do the PCIII and re-map to get some action? That would be around $300 for parts and how hard to do? Suppose the airbox would be easy.
    Yamaha lover
    I would think a cam, the PC3, and a pipe would be good. Jon would know...
    Wistah
    Quote Originally Posted by fjrrider RI View Post
    If you go with just the PCIII, the most you'll get is mucher smoother throotle response, though 1 or 2 hidden hp is possible with the right tune. I'd take it to a good shop that can run it for you...you can set it with the pre-loaded or downloadable maps, but there are always variables. It's fairly easy to put on, the only hard part would be getting the airbox out. Its really easy on some bikes, not so on others.
    As far as getting the snorkels off, that's extremely easy, but a tight fit (unless you pull the whole box out). Grab inside the airbox with pliers and pull. But its not beneficial unless you pair it with a higher flowing air filter. Doing so will cause extraneous popping and flame bursts, which is why you need to plug the PAIR valve. Those things pretty much need to be done all at the same time.
    Narragansett, RI
    thanks for the info!
    Yamaha lover
    Raymond NH
    Easiest and cheapest way to increase torque and acceleration is to swap the chain and sprockets. It'll still pass inspection and be quiet. Won't help HP though.
    South Windsor, CT
    The biggest gains you will see for this bike have to do with air flow. The motor is really choked down from the factory and responds well to increased air flow.
    Narragansett, RI
    Quote Originally Posted by Jonny Rocket View Post
    I believe the air flow increase would have some effect since the motor sounds like it wants to wind faster. What new filter would you recommend?
    Yamaha lover
  1. 2009 Ninja 650R
    By Cowboyrider in forum For Sale
    Last Post: 08-27-14, 10:09 PM
  2. Ninja 250 motor transplant... what motor to use?
    By DynoTune in forum General Bike Related
    Last Post: 01-06-14, 08:04 AM
  3. Ninja 250 motor vs. clutch grenade?
    By feralchimp in forum General Bike Related
    Last Post: 09-17-13, 09:27 AM
  4. 650 ninja 2009 pics
    By fjrrider RI in forum General Bike Related
    Last Post: 01-20-10, 11:52 AM
  5. New Jersey Motor Park Theft Sept 21, 2009
    By digitalkok in forum General Bike Related
    Last Post: 09-23-09, 04:51 PM
