Results 1 to 13 of 13
Accidently shifted into neutral and clutch into next gear produces out cachunk noise.
    Dec 2019
    Andover, MA
    Hello everyone...
    I've noticed that while riding my Street Triple RS that when I shift from 1 - 2 or 2 - 1 and I hit neutral instead. I would pull the clutch back in and shift.
    However that shift is very loud compared to a proper shift.
    Can this be a problem? Transmission?
    The louder shift can happen in either direction. I don't want to damage my transmission as that is a costly repair I do not need
    If that is semi normal, any ways to help smooth that shift out if it does happen again?
    Re: Accidently shifted into neutral and clutch into next gear produces out cachunk no
    Sounds normal to me.
    When you're in gear, every spinning part in the transmission is spinning. When you go to Neutral some of those parts stop spinning (or at least they slow down)... but the bits attached to the front sprocket and drive train keep going, being spun by their respective power sources.
    When you get it back into a gear, the parts that stopped start spinning again and everything gets reconnected, so what you're feeling with that "clunk" is the spinning bits re-engaging the non-spinning (or slower spinning) bits and matching speeds.
    https://www.youtube.com/watch?v=IFjSVgNFd6E
    Skip to about 2 minutes in for a visual. Each time he goes into a new gear by hand he momentarily puts it into a false neutral and you can see that some bits stop turning.
    btw, thank you for asking this question because it made me think about it a bit more. I knew that what you were experiencing was normal & I was pretty sure that I knew why, but this helped me confirm what I thought I knew and I was able to find a video that clearly demonstrated it for me.
    Dec 2019
    Andover, MA
    Thanks, I remember seeing a similar video but not as details on Youtube..
    I always thought even if the clutch pulled in the gears would still rotate from fluid drag of the oil.
    They do usually keep spinning a bit as you can kinda see in some parts of the vid, but they're not all locked in like they are when the bike is in gear so there's going to be some speed differential when they re-engage. That's what you're feeling, that "impact".
    Perhaps saying they "stopped" spinning is misleading. They may stop, but those that don't will be spinning more slowly.
    Lifer JettaJayGLS's Avatar
    Tahoe City
    It is definitely a disheartening noise. The best way to minimize is to go up a gear instead of down when it happens. You still get the noise, but the spinning parts have less leverage on the non-spinning parts. At least that's how it works in my brain.
    Just like bump starting - smoother in a higher gear than a lower gear.
    Lifer golden chicken's Avatar
    Attleboro, MA
    You are rev-matching, right?
    You shouldn't be finding neutral that often. Either shift harder or make sure you're letting the shifter return to detent after each shift.
    There is no rev-matching in neutral. Friction (precession actually I believe) and the speed of the rear wheel is all that's affecting transmission speed. Revsdon't have anything to do with it.
    Unless you mean BEFORE the missed shift, in which case, carry on.
    Lifer jimmycapp's Avatar
    Oct 2008
    NW CT
    Not sure if it was just mental, but the FJR would "feel" more of a clunk when the oil was due for a change. Also, make sure you're not lazy shifting the lever. R1 loves to catch neutral when I'm short shifting 1-2, usually in front of people.
    Banned G21forme's Avatar
    Lakes
    My 636 did the same, bought it used but 1 to 2 had to be a deliberate solid shift, not so past that.
    rides bikes
    Nov 2014
    I was going to say the same. If you're hitting neutral a lot, it's probably time for an oil change. I basically stopped tracking mileage between oil changes, now I change the oil as soon as the transmission feels the slightest bit different. This usually results in me changing oil 2-3k.
    Dec 2019
    Andover, MA
    Thanks Nick,
    I've changed the oil back 1500 miles ago (give or take a hundred).
    I would not think it would need it again. I do think it is more the lazy shifting... I have a quick shifter that I am used too and maybe I dont shift assertive enough from 1 - 2 or 2 - 1.
    It happens maybe 3 or 4 times when riding around the streets for a couple hours.
  1. FZ6 stuck in neutral?
    By Beam in forum Bike Maintenance
    Last Post: 06-23-14, 11:48 PM
  2. GSXR in Gear Clutch Disengaged and Difficult to Roll?
    By LXnastynotch93 in forum Bike Maintenance
    Last Post: 01-13-14, 03:20 PM
  3. No Neutral
    By slammp in forum Bike Maintenance
    Last Post: 03-12-12, 08:57 AM
  4. Finding neutral
    Last Post: 06-30-11, 03:23 PM
  5. that unexplained noise might be your sissor gear
    Last Post: 02-08-05, 01:22 AM
