Results 1 to 23 of 23
When to Adjust Valves?
    I just rolled 15k on my 04 ZRX and was wondering when I should think about checking the valves...
    Savannah, GA
    Re: When to Adjust Valves?
    yes.
    if at low throttle inputs it gets a bit choppy, or you feel vibration you didnt feel when it was new, or if it doesnt start as easily as it used to, or all sorts of things. If you've never done it, it definately does not hurt.
    The best advice I’ve ever been given is to not forget where you came from.
    Lifer catamount's Avatar
    Sep 2006
    Colchester, VT
    I just checked the valves for the first time on my 15k Triumph 955i. All of my exhaust clearances were too tight.
    So... now is a good time
    Ahh ok thanks guys. Looks like I will have to get some shims and read up on it. And take the street bike out of commission for a little bit.
    Savannah, GA
    you can order oneo f the hotcams shim kits... they work great and they have a little of everything which is nice.
    Lifer Stromper's Avatar
    Eastern Ct
    If you are hard on the bike you are overdue
    MY last Yamaha said 26K but every valve needed it at 12K
    shims come in 2 diameters know which kit you needd
    Lifer obsolete's Avatar
    Norf Sho
    I gotta do the SV as well. There are kits you can buy ahead of time instead of checking and then buying the one needed? That helps a great deal.
    -Alex
    Sep 2006
    Colchester, VT
    Shims are expensive! $5-14 depending on where you buy them. And sized in quarters of a MM. Some dealers will trade you shims for your old ones (plus a couple bucks).
    And, you may find that you can move some shims from one valve to another depending on what size is needed. This will save you money!
    In other words, don't buy them until you know which ones you need!
    Otherwise you're going to be wasting a lot of them.
    Before doing ANYTHING, measure your tolerances.
    You may not need to change a thing!
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Thats not funny enough. Slipping?
    Norf Sho
    I figured you’d be used disappointment after all these years.
    -Alex
    Norf Sho
    Quote Originally Posted by catamount View Post
    This is what I had figured. Just sucks to have the bike down on a weekend and maybe have to wait till the next weeked to get it back together.
    -Alex
    Central MA
    [B]
    OR.... because the values will generally get tighter over time, you use a piece of plate glass and wet/dry paper and sand down your existing shims to the exact size you need. This in combination with the swap between values method prevents a bunch of runs to the dealer.
    Atkinson, NH
    Why wait to see what you need before you buy them, and then be at the mercy of the dealer or have to order them online and wait?
    Go here:
    http://lukesracing.com/Merchant2/mer...gory_Code=HCSK
    And buy these for the ZRX:
    Refil Shim Package 9.48mm OD x 2.40-2.65mm
    Code: HCSHIM11
    Price: $28.00
    Quantity in Basket: none
    Refil Shim Package 9.48mm OD x 2.70-2.95mm
    Code: HCSHIM12
    Price: $28.00
    Free shipping for orders over $50. You get more shims than you'll need for $56 shipped.
    btw - I am not affiliated with Luke's Racing - I just bought shims for my ZRX there.
    Raymond NH
    I have a complete shim kit that fits your bike and would be happy to swap with you. Just bring your old shims and a list of what you need.
    Norf Sho
    Thanks man! I think I may dive into it next weekend but I'll be in touch and work something out with you.
    -Alex
    Raymond NH
    It's an SV 650 right? The SV1000 takes different shims. Mine only fit the 650. sory if I got your hopes up.
    Eastern Ct
    The last 2 times I did valves they all needed smaller so little swapping could occur.
    IF you know a machine shop with a surface grinder then you can take down your current ones
    Norf Sho
    Wow, I just felt like every woman that's ever got in Rambuncous' pants.
    Thanks for the thought though man!
    -Alex
    Thanks for the good info guys.
    I Dance With Will
    Oct 2002
    unknown
    Quote Originally Posted by FirstLightning View Post
    genious.
    anyone wanna swap shim just for fun?
    "fuckit!"
    Lifer Punjistick's Avatar
    Norwell, MA
    We should all pick a weekend to check our valves and do a shim swap
    NorthShore
    Sounds like a "Show me your shims, I'll show you mine" kinda deal. Glad my bike's only got 5K on it. Don't NEED no shims. Course, dunno if a Concours/ZX14 uses shims. Dunno shit about bikes. How do you peeps do it, with the keepin' yer bikes runnin? Jesus H., just to get enough fairing off to check the battery vexes me.
    Quote Originally Posted by toocrazy2yoo View Post
    I naked bikes.
  1. $$$ carbs cleaned/adjust
    By sluggah in forum General Bike Related
    Last Post: 07-19-10, 09:27 PM
  2. adjust clutch
    By cookie in forum Bike Maintenance
    Last Post: 04-24-10, 05:30 AM
  3. Idle speed: how to adjust?
    By chr|s sedition in forum General Bike Related
    Last Post: 08-07-06, 07:40 PM
  4. Valve adjust demo
    Last Post: 05-08-03, 07:30 AM
  5. How do I adjust this?
    By Kham in forum Bike Maintenance
    Last Post: 12-22-02, 07:52 PM
