Results 1 to 12 of 12
Need some advice on supporting front end
    Jun 2016
    Foxboro
    I am replacing my steering head bearings this weekend and need to find a way to support the front end of the bike since I wont be able to use my stands. My current plan is to just put a ladder over the bike and use some ratchet straps tied around the frame sliders. The ladder feels like a flimsy piece of junk but I use it all the time so I see no reason why it couldn't support the 200-300 lb portion of the bike for a few hours. Any glaring flaws you guys see with this approach? This sounds kinda lazy but ideally I'd like to be able to get the front high enough so I can pull out the forks and wheel as one piece but I don't know if that will be possible with this setup
    Need some advice on supporting front end-1494860643221-jpg
    Lifer Imbeek's Avatar
    Sep 2012
    Southwick,MA
    Re: Need some advice on supporting front end
    Check this thread from a week or two ago. You will probably need to remove the front tire...
    HF Shop Crane
    Have you no beams you can loop in that garage?
    i've done the ladder + straps trick in the past (as well as garage door rails + straps), worked fine. i removed the front wheel before tearing the rest down.
    Lifer golden chicken's Avatar
    Fitchburg, MA
    I'd use jack stands under the frame sliders if they clear the fairings enough.
    Nov 2009
    Bristol County
    I've not tried the ladder method but I thought it was pretty standard practice? Loop it to the ceiling too.
    Or put the rear tire up on a swing arm stand, remove the lower fairings, and see if there's a spot you can lift the front with a jack. This method can be a little sketchy though as the front of the bike isn't supported so it could fall off the jack. If the ladder makes you nervous, combine the ladder and floor jack.
    nedirtriders.com
    Seacoast NH
    Worked for me.
    Need some advice on supporting front end-img_2946-jpg
    Jack stands under the sliders works too.
    Just kick it over and lay it on it's side. WAY easier.
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    I do that just to change the rear tire...
    Junior Member Stevie's Avatar
    Apr 2015
    Londonderry, NH
    Wanna use my lift?
    Need some advice on supporting front end-20170122_182950-jpg
    Anyone who lives within their means suffers from a lack of imagination.
    - Oscar Wilde
    I was talking to a buddy of mine who has a harley with bags and that thing is heavy and chromed out with lots of flake in his paint. How do people lift bikes like that usually? Center stand jack? No spots for stands like street bikes. I just feel bad that i have the tools and such but no clue on how to position the bike to swap out tires and the such.
    Mar 2012
    Chichester, NH
    1500 lb. Capacity ATV/Motorcycle Lift
    I bought a dedicated MC jack for my GL. Never used it, but something like this is common for baggers.
