Results 1 to 9 of 9
Afterfire
    Feb 2008
    Devon/Surrey, England
    Afterfire
    Hi Folks - just a quick question really.
    Noticing over the last year and change increasing afterfire/popping on overrun, especially if using engine braking on a downhill grade.
    While it does sound rather badass, sign of a potential lean condition?
    Plugs changed at 20k over to iridium, no real change.
    (Debating a PC3 if so)
    (Bile is a R1200GS, 07 - my last two beemers had farily little afterfire/popping)
    Giles
    Just Registered
    Is it not obvious?
    Re: Afterfire
    I was going to ask if you have ever checked the exhaust out on your GS... I noticed one day I had a weird leak on mine at the header to exhaust pipe transition, like it just wasn't put on all the way...weird. All I notice was less perceived pinging as a result - but in hindsight I think it was just unmuffled exhaust popping through the gap.
    They didn't upgrade the GS enough to my liking so I have to wait another year or two before I decide this issue freaks me out and I need to trade it
    www.gpsdiscussion.com
    motorcycleaddicts.org
    Feb 2008
    Re: Afterfire
    Quote Originally Posted by ssg View Post
    Hmm - I'll go over it again, might've missed something.
    I know what you mean RE upgrades - not a fan of the post-07 styling. Still, the DOHC head change stuff could be very very interesting!
    Just Registered
    Is it not obvious?
    Re: Afterfire
    The DOHC stuff is only step 1, I'll give them a year or two to play with it then buy the version with the real HP bump.
    Although the valve adjustments now are so easy.
    I will be interested in your findings whatever happens because I have noticed my bike does do this a little more as it ages...but not enough I ever considered it to be something of annoyance or concern.
    Feb 2008
    Re: Afterfire
    I'm going to have a thorough test of it tomorrow PM - I'll let you know what if anything I find. On the upside, it is hilarious to be able to do it on command (close throttle, crack it open a touch quickly, pop pop bang burble burble, doubly so if next to someone in a convertible on the phone.
    The big downhill stretches on Route 2 are *ideal* for this
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Re: Afterfire
    I like the exhaust then valve adjust anglr
    Back in the drag racing day
    cruise at 50 plus
    engine kill of
    throttle open
    engine kill on
    extra fun with open collectors also at night should be good for 4 ft flame show
    Glen Beck is John the Baptist
    Lifer Trouble's Avatar
    Monkton, VT
    Re: Afterfire
    Quote Originally Posted by Wanderer View Post
    That or when bicyclists insist on riding 2 and 3 abreast.
    If I run my FZ6 at 6k rpm for a little while and then snap the throttle closed it's do it.
    LRRS EX #7
    Low Down Racing
    Aug 2004
    Baltic,CT
    Re: Afterfire
    I'm so old I am sure now the injectors shut off with the kill switch
    I guess you have to install a separate ignition only kill switch
    Lancaster, CA
    Re: Afterfire
    The Buell does it on command on decel... Never tried the engine-off-engine-on thing though, that might be fun...
