Results 1 to 9 of 9
Alternative to Dzus Fasteners
    Lifer JettaJayGLS's Avatar
    Tahoe City
    What are you guys using instead of Dzus? I don't like the quarter turn, I want something that actually threads in. My bodywork isn't that great, doesn't line up perfectly, and the lower mounts to the upper in a very narrow spot so there is only room for 2 fasteners instead of the standard 3. I want those 2 fasteners to be SECURE. Right now I've solved that by ziptieing or safety wiring the dzus clips to one another.
    I'm fed up with it to the point that I'm considering just buying new body work...but mine really isn't terrible and I'd rather spend that money on a million other things.
    I want to rivet the base clip to the upper body work, I do not want a "clip-on" style fastener.
    Is there something out there? I swear I've seen them before.
    Thanks folks.
    Re: Alternative to Dzus Fasteners
    I use rivet base d-zuzs, you can get rivet on 'anchor nut' plates that will take full threaded fasteners. Bear in mind you'll need to bush the screws so they never actually compress the glass bodywork or it'll crumble in short order. Metric Self-Locking Nut Plate, Floating | Pegasus
    Edit: You can adjust the tension on the D-zuzs fasteners too fyi, either by tweaking the clip or playing with teflon shim washers.
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    Check speedyfasteners.com, they have a bunch of options. For some reason it's being blocked for me at work for malware or something at the moment though.
    Google has thrown up a block as well, looks like either an ad banner or something else is attempting a drive by malware install on the site.
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    Look up "speed nut clip"
    Tahoe City
    Yesssss that's what I want. Maybe I just bought cheap Dzus, but they never worked great from the start and have gotten significantly worse over time.
    Blocked for me as well
    Not sure I can safely google that at work without getting fired.
    Jul 2014
    Central CT
    Lol... It's safe. Only thing that comes up is relevant information.
    Jul 2014
    Central CT
    Lifer Pittenger5's Avatar
    Austin
    Is there a way to use a dzus fastener of some sort instead of a screw? My bodywork is held on by dzus fasteners except 2 stupid screws, so I always hafta go find the right allen to get the damn body work off.
    Zip Tie Alley #505
  1. WTB: Dzus Fasteners
    By j4eric in forum Wanted
    Last Post: 07-21-12, 06:58 PM
  2. dzus fasteners
    By Ray-Ray in forum Wanted
    Last Post: 05-18-11, 04:21 PM
  3. Which Dzus Fasteners?
    By Fastsc92 in forum General Bike Related
    Last Post: 11-10-10, 04:42 AM
  4. rivet attached dzus fasteners
    By Jayspeed in forum General Bike Related
    Last Post: 05-01-08, 03:49 AM
  5. dzus body fasteners
    By Kitt in forum Pit Area
    Last Post: 08-28-07, 05:47 PM
