Results 1 to 2 of 2
Clutch won't engage after reassembly.
    Junior Member SteveZX9er's Avatar
    Jan 2012
    North Hampton, NH
    So I cracked the engine lower case on my 97 ZX9R over the winter and replaced the bent 2nd gear shift fork. I got the engine back in the frame and ready for a test ride, but my clutch won't engage. If I put the bike in 1st gear and let out the clutch, the bike rocks slightly like it wants to go, but then nothing.
    It's a hydraulic clutch, new fluid, bled it thoroughly. I put everything back together per the service manual. I'm thinking clutch springs are out of spec? That or I need a new (thicker) steel plate.
    I'm open to suggestions as to how to approach this.
    Thanks!
    "I'd rather have a bottle in front of me than a frontal lobotomy..."
    Posting Freak
    New Hampshire
    Re: Clutch won't engage after reassembly.
    I'm not real familiar with that particualy engine but..... on a lot of bikes you need to line the pressure plate up right. there is usually a mark on the basket that you need to line up with a mark on the pressure plate. Worth a look
  1. Clutch spring...lessen clutch pull
    By black in forum General Bike Related
    Last Post: 06-29-20, 10:25 AM
  2. Wanted - Parts & Tools | Clutch perch bolt for 03+ SV650 (or complete perch) also 00-03 GSXR clutch perch
    By juha_teuvonnen in forum Wanted
    Last Post: 05-22-18, 10:57 AM
  3. For Sale - Parts & Tools | Yoyodyne slipper clutch, Ducati 848 wet clutch
    By jwm2k3 in forum For Sale
    Last Post: 04-27-17, 10:07 AM
  4. WTB: 06/07 R6 Clutch
    By Kitt in forum Wanted
    Last Post: 03-30-11, 11:33 AM
