Results 1 to 14 of 14
Hosed SRAD
    Feb 2012
    Hosed SRAD
    Been storing my 750 SRAD that I rode all last season in my garage and suddenly this season the tank started leaking. So I picked up a new OEM Suz gasky from B Courts. Pulled the pump out and uhhhhh this looks like shit. I'm gonna try some Permatex blue jiZz and see if it seals.
    A "used" pump on eBay is like $350. What is my alternative if this doesn't seal ? $350 for a used questionable pump seems silly. Can this unit be fixed ?
    Thanks
    Too many bikes to list
    Mosdt likely drunkd
    Oct 2020
    Chelmsford, MA
    Re: Hosed SRAD
    permatex will not hold. you need a proper fuel gasket ring to seal it.
    holland ma.
    Re: Hosed SRAD
    This is becoming quite the problem with the old srads. Look on gixxer.com for all the attempted repairs.
    Feb 2012
    Re: Hosed SRAD
    I bought an OEM gasket and bolts dawg
    The Permatex is a dressing
    Mosdt likely drunkd
    Re: Hosed SRAD
    It will only make things worse once it starts to break down.
    Lifer joeswamp's Avatar
    Sep 2006
    Swampscott, MA
    Re: Hosed SRAD
    Hylomar is a gasket dressing that doesn't break down in the presence of fuel (and I believe it's blue). Really good stuff for this purpose. I think Permatex now makes it under license -- might be what you have. If you clean everything really well and use a new gasket dressed with this stuff you should be good.
    Joe
    04 Thruxton (Street)
    01 SV650 (Track)
    Oct 2020
    Chelmsford, MA
    Re: Hosed SRAD
    Hosed SRAD-image_2023-06-22_111536249-jpg
    Permatex is RTV (silicone). It will not hold gas for very long.
    You need a nitrile gasket or silicone rubber gasket.
    https://jehbco.com.au/products/chemi...ibility-chart/
    Oct 2020
    Chelmsford, MA
    Sep 2006
    Swampscott, MA
    Re: Hosed SRAD
    This is the stuff:
    https://www.amazon.com/Permatex-8524...ct_top?ie=UTF8
    Except I'm not sure if Permatex is distributing it anymore, the Amazon link says currently unavailable. I used this on a similar application (a small tube came with a replacement fuel valve) and it's still holding up 15 years later. This stuff was developed by Rolls Royce for aircraft engines during WWII.
    You can order it from Amazon under the regular brand -- just search for 'Hylomar'.
    Joe
    01 SV650 (Track)
    holland ma.
    Re: Hosed SRAD
    Yamabond may be a good option as well
    Oct 2020
    Chelmsford, MA
    Re: Hosed SRAD
    threebond makes yamabond, hondabond, etc. don't pay more.
    Feb 2012
    Re: Hosed SRAD
    Fake
    Mosdt likely drunkd
    Feb 2012
    Re: Hosed SRAD
    This is what I used
    Probably gonna say the N word again so Oreo gaborio can delete it again
    Mosdt likely drunkd
    Sep 2006
    Swampscott, MA
    Re: Hosed SRAD
    Oh dear, looks like Permatex has reverse engineered Hylomar! Time for legal action, these gasket sealant wars are not pretty.
    Joe
    01 SV650 (Track)
