Results 1 to 5 of 5
Backfire issue HELP!
    Newbie JolleyBinks's Avatar
    Jamaica Plain
    Hey guys... I have a 91' CBR 600, fixed the problem with the gas leak and now I have the bike starting fine and running. However, when i really wined it out at high RPM and then let off the throttle I get a heavy backfire when the engine revs down and throttle is completely taken off ... this happens only under stress not when the bike is at idle and revved high then let go.
    Is the a common problem that can be fixed by and armature.
    I have 3 ideas ...
    Carb adjustment
    Ignition Timing
    Running lean
    Any suggestions I will really appreciate.
    Thanks for your help
    Binks
    Re: Backfire issue HELP!
    Quote Originally Posted by JolleyBinks View Post
    I have 3 ideas ...
    Carb adjustment
    Ignition Timing
    Running lean
    Carb adjustment & running lean is really 1 idea...
    But yeah, I'd say it's carbs. My guess is the backfiring is unburnt fuel...
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Exhaust leak okay? Check if your idle jet(s) are clogged.
    Lifer DuncanMoto's Avatar
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
    1st clean out all jets.
    Check spark plugs.
    Check timing.
    If it backfires after a couple seconds once the gas is let off the you're likely running rich.
    If it backfires pretty much right away once the gas is let off you're likely running lean.
  1. intake backfire
    By viper919 in forum General Bike Related
    Last Post: 04-20-10, 12:18 PM
  2. my first issue..... Help!
    By P_easy in forum Bike Maintenance
    Last Post: 09-11-09, 08:00 AM
  3. "Backfire" with aftermarket exhaust
    By The Snowman in forum Bike Maintenance
    Last Post: 07-07-06, 12:39 PM
  4. Backfire cause?
    By benVFR in forum Bike Maintenance
    Last Post: 07-14-04, 10:45 AM
