3
This will be the official thread for the basic motorcycle maintenance and servicing day at my house in Taunton, MA.
Im open to suggestions on dates for this but obviously a Saturday or Sunday.
Available dates
August 3/4
August 24/25
The aim of the day.
To provide a hands-on self-taught environment for a group of NESR members to learn some of the basic to mid-advanced techniques and procedures for maintaining and servicing their motorcycles.
I will endeavor to provide all of the tooling and documentation needed. Space is limited and I would like to have 2 other "facilitators" to help out and a maximum of 8 "students".
This class is not intended to be a "get your valves adjusted professionally for free" day. I will perform a "how to" on various procedures and you will have space and tools available to then practice the technique on dummy setups (engine in a stand, etc) and if there is time, to perform the procedure on your own motorcycle, with guidance/supervision.
The format will evolve according to who signs up, but I expect we would run 2 groups.
Group One would be for people who have never turned a wrench on their bikes. This group will cover:
Basic motorcycle pre-ride checks (10 mins class, tops)
Motorcycle tools, including torque wrench and t handles etc.
Oil change
Air filter check/change
Checking/replacing brake pads and fluid
Front and rear wheel removal and reinstallation
Coolant change
Clutch cable and throttle cable adjustment
Basic motorcycle electrics
Basic 4 stroke engine technology
Fi versus carbs, airflow / exhaust changes.
Group two would be for people proficient with the above basics and will cover:
Chassis -
Front and rear suspension removal/reinstallation
Swingarm removal/reinstallation
Steering head and wheel bearing replacement
Operation of tire machine
Engine
Clutch removal/replacement
Valve-cam lash check/adjustment (in line 4, shim under bucket, chain driven cams)Camchain tensioner lifters
Semi-advanced 4 stroke tuning techniques
If you want to adjust your valves, you MUST have the bike at my place EARLY. The engine must cool down for at least 4-6 hours BEFORE adjusting valves. I will have valve shims here for exchange if needed.
If you want to change bearings, you MUST bring bearings with you so we can freeze them for a few hours.
I have 1 lift, a few stands and limited room. Some of you may end up here all evening due to time/space constraints. The bike lift will be utilized by basic in the morning and advanced in the afternoon.
I will have a 2005 CBR600RR motor on an engine stand for valve lash class/practice.
Class attendees will need to bring any supplies/consumables they wish to change WITH THEM or mail them to me prior to the day OR have me obtain them and reimburse me on the day.
All attendees will go home with a set of JIS screwdrivers. The more of these we can get out there, the less buggered screws there will be on bikes (thanks for the idea NHBUBBA).
I will provide refreshments. I also have a small in ground pool to cool off in. We will stop for an hour for lunch.
Suggested donation for supplies, lunch, screwdriver set, expertise.
Basic = $50
Advanced = $100
Amounts donated will not be shared with other attendees. If you don't want a JIS screwdriver set, drop your donation by $25. There is no minimum, but don't be a cheap prick :-). If you are a starving student or unemployed, I will understand. Don't arrive on your Panigale and tell me you're broke though.
"facilitators" will each receive a JIS screwdriver set and refreshments for their time.
Leave any attitudes at the door. Bring your sense of humor.
My house is firearm-free. If you want to carry concealed, you had better keep it concealed or you and I will have a problem. I love guns, but I don't allow them in my house.
I suggest you bring.
A flashlight
A service manual for your bike if you have it
Stands if you are trailering your bike
A good set of feeler gauges if on the advanced course. Make sure they go down to .002" if possible. Try to either but the really long ones or the angles ones. Short straight ones are useful only for making tables not wobble.
Bring your torque wrench if you want to check it against my calibrated torque wrench.
First 4 to sign up per group will get the spots. CEO and Jimmy, you don't count. You will be facilitating and using your bikes to teach.
Put your screen name, real name, class you want and any date you cannot attend.
Jesus. the forum fucked up all my spacing. I'll try to edit it.
Internet explorer sucks. Screwed up the format and wont allow me to save an edit. Switched to Chrome and all is well. Bill Gates, you suck.
In for beginner! I'm free the first two sets of dates.
Screen name/real name: daisha![]()
Class: Aug 3/4
Unavailable: Aug 24/25.
Bike: 2006 Ninja 250
Edited to remove 17/18 & add bike
Are both groups meeting on the same day? It would be great to join Group 1 one day so that I am ready for Group 2. Either way, thanks you Derek for doing this! This is exactly what I need as I would rather learn myself on how to maintain my bike. I added my type of bike just in case that matters.
Screen name: Virtualbong
Real name: Wilson
Class: Both if possible
Unattendable Dates: Aug 3/4 and Aug 25
Bike Model: 2008 Ducati 848
Will, knowing you, I suggest signing up for the advanced and we will play catch up to get you the basics. The classes will be on the same day as my time is extremely limited. As long as you dont intend actually adjusting your valves that day, there will be time for you to catch up on both classes.
I took august 17/18 out as that is a race weekend and chris and jim wont be available.
Great Idea Degsy.
Screen name: Billy
Real name: Billy
Class: 2nd group for Engine
Unattendable Dates: All weekends in August are open for me
Bike Model: 2006 GSX-R 750 2012 Kawasaki Z1000
I dont need anything done on my bikes. Just want to practice on "dummy engines". Is harassing Jim encouraged?
we do a bunch of these out in socal...
I recommend:
-bringing a grill and chicken!
-your local detailer (landrics?) can detail the bikes for $35/pop
Screen name: pontifex
Real name: Ivan
Class: Basic
Unattendable Dates: none
Thanks for doing this Degsy. Hopefully you will do another advanced after this round so I can take that as well.
Would paypal in advance be preferred?
Screen name/real name: Karate.Snoopy / Nitin
Class:Basic
Dates: Aug 24/25 (baby expected in Mid July so early Aug3/4 might be tough but doable)
Bike: 2007 Yamaha FZ6
Id love to help out but I'm teaching msf both those weekends. If the dates change let me know.
Screen name: StrayNut
Real name: Alyssa
Class: Advanced (I wouldn't call myself "proficient" at the topics in Basic, but I can muddle through, and will be replacing the clutch this winter)
Unattendable dates: none of the ones listed
Bike: 1989 Honda CB-1
Wirelessly posted
Maybe scottie can come down and help facilitate. :-)
The 25th is my anniversary, but if I'm around, I'll gladly come give a hand.
Probably Saturday, that is...
Wirelessly posted
Excellent chipper.
You'll be asking hardcore to help out too I assume?
Shit like this gives me the warm 'n fuzzies. This is a really solid thing to do.
im pretty proficient with turning a wrench and working on my bikes but id be willing to come down and lend a hand with the basic peoples if needed but will not 'participate' as to leave space open for others who need it more than I do. I could also bring a pad rearstand, a spool rear stand and a triple tree front stand with assorted pin sizes if needed
Screen name: lord1234
Real name: Leo
Class: Basic
Bike Model: 2008 Yamaha FZ6
Great Idea Degsy.
Screen name: IMSTuner
Real name: Jeff
Class: Group two
Unattendable Dates: All weekends in August are open for me as of right now.
Bike Model: 2008 Yamaha R1
I might need to mount 2 sets of tires and might need to mount my Ohlin forks and shock.
Degs, you know I'm in. I'll bring my race tool kit as well and am happy to help grill, cook, or any other 'facilitation' ahembackrubsahem that is required.
I HIGHLY recommend folks label any and all important tools you will be bringing to avoid ANY confusion.
Last thing we want are people heading home and realizing they're missing stuff. Just a thought.
I lost a bottle of Captain Morgan there once... I knew I should have put my name on that shit!
Screen name: 7UPyours
Real name: Martin
Class: basic
Unattendable Dates: either weekend works for me,
Bike Model: 05 Yama fz6
Name: reks95 / Rick
Group: Basic, although I'd like to hang around to at least see valves done
Dates: All are good for me
