Results 1 to 14 of 14
Battery issue - bike won't start
    Member NH848's Avatar
    Sep 2012
    Seacoast
    My 2010 848 shut off while doing around 20-30 mph yesterday. Bike seems to turn over but won't start.
    Battery voltage indicator was giving me a reading of 11 which is below the 12.1-14.9 range it should be. Got it home and put the battery tender on. Got it back to range but again won't start. I suppose next step is to get a voltage meter and start getting readings with the ignition on and off.
    Any ideas on what else I want to check? Not sure how old battery is. At least several years.
    Thanks in advance.
    Re: Battery issue - bike won't start
    If it turns over easy then the battery is not your issue. Enough to turn over is more than enough to run.
    You'll need the motor running to diagnose the charging system. Fix that first.
    Key on/off voltage levels are not that interesting. You are most interested in engine running @ ~3-4k. At that RPM there should be >13VDC reading off the R/R. Less and you have a problem with either the stator or the R/R or both.
    Lifer Tekime's Avatar
    Mar 2016
    Falmouth, ME
    The old battery on my GS had enough power to turn it over, but still no start. Just didn't have enough punch.
    Can you bump start it?
    05GSXR75005SV65090DR350
    I would debate that statement.
    If the battery has enough voltage to turn the engine, that's one thing. If the starter is dragging the voltage down far enough, there is a point where the ECU (in this case) will not have enough voltage to function even though the starter sounds like it's rolling the engine over just fine.
    This is common with older Polaris ATV's. Plenty of voltage to turn the engine over but not enough to actually get spark.
    Aug 2015
    New Haven
    Shutoff while riding, sound like electrical issue to me...I would check, Fuses, Spark and fuel pump to start
    Of course you would. This is NESR!
    More like, of course I would because "enough to turn over is more than enough to run" is a false statement.
    Lifer Stromper's Avatar
    Eastern Ct
    Some electronics need at least 9 volts to fire
    When a weak battery is turning it over the system voltage will drop below and ECU and injec tors will not function
    I would jump it from a car (carefully) if she fires right up its the batter
    an abused battery 1 year a cared for battery maybe 5, let it drain to nothing and its toast, or a POOR maintainer and its cooked
    If you can check fluid and add distilled water (supermarket) if it needs it
    The calculus of hate
    Sep 2012
    Seacoast
    I should have been more broad in my subject. Not sure it's a battery issue anymore. First of all, thank you to those who have contributed. It's really nice to have a community like this. Upon further research I am wondering if my fuel filter disconnected. When I turn the engine over with the fuel cap open I see a swishing inside the tank. Not sure if that is supposed to happen.
    I am going to take the tank off an inspect the inside to see if everything is still connected.
    Mar 2004
    Lynn, MA
    Pat, post this up at ducati.org | the home for ducati owners and enthusiasts
    Theres some motherfuckin scientists over there.....
    Sprag clutch. Thats a big issue with our bikes. Hope its just a disconnected fuel line or bad battery.
    Sep 2012
    Seacoast
    Thanks Johnny. I certainly will. Here's the thread:
    Troubleshooting Help Needed for 09' 848 - Page 3 - ducati.org forum | the home for ducati owners and enthusiasts
    And here is the outcome. Pulling the fuel pump out of the tank was like the moment when you pull a baby out of the womb and have that aha reveal. "It's a boy". Or, "it's a disconnected hose".
    Battery issue - bike won't start-image-jpg
    They just don't crimp 'em like they used to. I'm guessing the hoses can't stand the ethanol?
    Sep 2012
    Seacoast
    SSC would agree with you. My thoughts having watched previously referred to thread is poor clamp design. Other theories include rough riding/jarring from a wheelie. I don't buy that one.
    Mar 2004
    Lynn, MA
    Im happy it was only a disconnected hose!
    Brapp on!
  1. 01CBR929 will not start with new battery
    By CBRRdee in forum Bike Maintenance
    Last Post: 10-24-14, 11:03 AM
  2. Registration Issue with old bike
    By Petorius in forum General Bike Related
    Last Post: 05-10-14, 03:46 PM
  3. Issue with bike starting
    By Billy in forum General Bike Related
    Last Post: 03-07-06, 07:29 PM
  4. Battery charged by still no start...
    By SVGirl in forum Bike Maintenance
    Last Post: 02-26-04, 03:23 PM
  5. Daytona would not start - battery?
    By NHViffer in forum General Bike Related
    Last Post: 07-02-03, 09:46 AM
