Results 1 to 17 of 17
Bearing Removal.
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    Bearing Removal.
    I am having one hell of a hard time getting some damned bearings out of a wheel hub!!! I tried brute force, brute impact, diffrerent oils and solvents and heat.
    obviously, i cant get directly behind the bearings to knock them out directly.
    any other ideas on how to get the damn things out?
    Brent LRRS #772
    2006 KTM 560 SMR
    ultrabuddy twrayinma's Avatar
    Apr 2002
    albukoikee
    Bearing Removal.
    jackhammer?
    Bearing Removal.
    Small explosive charge? Tee hee...
    Sorry, I don't have any experience with this. Wish I could be of help...
    Walpole
    Bearing Removal.
    Why cant you get behind them at all? I may be able to help.
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    brass drift big fucking hammer
    gingerly hit the fucker b carefull is it in a rim put something in back watch the disks
    www.bostonmoto.com
    Forum Rules
    Jon and Clara's Dad snaggle's Avatar
    Mar 2002
    Walpole,NH
    Bearing Removal.
    Do you need to reuse the bearing??
    '04 600RR
    Newbie
    Sep 2002
    southern NH
    Bearing Removal.
    Usually the sleeve/spacer between the bearings is designed to tip from centerline frome one side of the wheel (insert a drift or punch smaller than axle about half way thru, then try to move sleeve).This allows you to use a punch to drive out one of the bearings. After you get the first out, then remove spacer, second bearing is now exposed on backside.
    Mar 2002
    Amherst, NH
    Bearing Removal.
    1) i do have new bearings to install.
    2)The big problem... i think i just dont have the right tool for the job. is there such a thing as a "bearing puller"?
    i can get one of the bearings to move about 1/4" almost allowing me to move the spacer back a tiny bit so i can *almost* catch the edge of the axle on it. i dont have anything else that can get in there. i tried a screw driver and bent the damn thing. i have some bent tip needle nose pliers, which i also bent, further than they are supposed to be... grrr.
    i just dont have anything that can get behind the bastards.
    i am close to getting the drill out with a 1/16" bit and making swiss cheese of the outer ring of the bearing on one end. then i will be able to get behind the other one and drive it out.
    Brent LRRS #772
    2006 KTM 560 SMR
    May 2002
    Meriden CT
    you got 2 cock that axle tube thingy
    just a little keep hitting it will come out or send it 2 degsy hes cheaper then a shop i would go do it piss you off real good but your 2 far i aint going over no rainbow ya git hey rabid you got ruby slippers he could do it 2
    www.bostonmoto.com
    Forum Rules
    Walpole
    Bearing Removal.
    They do make bearing pullers but they need to get behind the bearing as well. Get a long punch and tap the bearing out from the other side turning the wheel after every TAP, dont slam it cause it will just jam, you think its tight now....hahahaha. If ya need a hand let me know.
    2000 Ducati 900ss
    Mar 2002
    Amherst, NH
    Bearing Removal.
    based on the puller idea...
    i gotsk it!!!!!!
    took this thing i have, think its a flywheel puller, but i have never pulled a fly wheel so i dont know for certain.
    anyways, i latched it around the wheel hub and tightened it down til the center part violated that bearing in a bad way...
    this is good,
    then i backed it out, but had the hub jammed in my vise and the arm of the puller down against the workbench, so the center bolt thing was jammed into the core of the bearing....
    and the bearing LOST!!!!!!
    YEE HAAA!!!! That much closer to having this damn thing running.
    thanks for the advice guys.
    the next project is to figure out how the throttle cable connects to the top of the carb... its a little different than any motorcycle throttle i have seen. i am thinking of getting a nice little mikuni carb for this bitch and getting rid of the stock carb entirely.
    Brent LRRS #772
    2006 KTM 560 SMR
    Walpole
    Bearing Removal.
    Now your talkn'.......Man that sure would make a great pit bike
    2000 Ducati 900ss
    Mar 2002
    Amherst, NH
    Bearing Removal.
    yes,
    yes it would
    Brent LRRS #772
    2006 KTM 560 SMR
    May 2002
    Meriden CT
    what u working on 2 stroke
    cable goes 2 the slider
    www.bostonmoto.com
    Forum Rules
    Mar 2002
    Amherst, NH
    Bearing Removal.
    4 stroke 50cc honda.
    Brent LRRS #772
    2006 KTM 560 SMR
    Newbie
    Sep 2002
    southern NH
    Mar 2002
    Amherst, NH
    Bearing Removal.
    oh believe me, i have become good friends with Lyle over there at classic minitrails.
    Brent LRRS #772
    2006 KTM 560 SMR
  1. Wanted - Parts & Tools | Any one have a Wheel bearing removal Kit........
    By Pigman in forum Wanted
    Last Post: 03-28-15, 06:04 PM
  2. Chain Breaker & Bearing Removal Tool
    By BigShel in forum For Sale
    Last Post: 08-09-11, 10:38 AM
  3. Powder coat prep and bearing removal.
    By clyons in forum General Bike Related
    Last Post: 12-26-09, 10:45 PM
  4. Steering bearing removal...
    By dwaltz61 in forum Bike Maintenance
    Last Post: 08-26-08, 08:26 AM
  5. Wheel & Swingarm Bearing Removal tool
    By keeena in forum Bike Maintenance
    Last Post: 10-27-07, 08:01 PM
