Results 1 to 6 of 6
faint white smoke?
    faint white smoke?
    is it condensation?
    1/10 times that I start my 1995 FZR600 cold, it farts out a very faint white smoke that's consistent with increasing engine speed. It's so faint, that it disappears into the air, ~1-2" out of the exhaust
    I can't repeat a pattern of when it happens, I changed the oil hoping that it was some sort of detergent in the cases, and sometimes I can make it go away by gently blipping the throttle...then the smoke ceases to fart out of the exhaust immediately, and it idles a liiiiiittle bit smoother.
    is it condensation, that just gets burned/kicked out when I blip it?
    could it be a valve?
    the bike never used to do this until a few months ago. It has 28k miles on the clock, and I've seen the low oil pressure light come on twice under my ownership...so I'm afraid the rings or valves or something is leaking something in there
    Senior Member Dannyf's Avatar
    Middleboro, MA
    Re: faint white smoke?
    White that disappears that quick is most likely condensation. Only other thing that really burns white is coolant. And it would linger a bit. Valve seals and the such would usually show as blue/gray smoke. But without seeing it i can't tell u 100%
    Dan
    does it go away once the engine is warm in ambient temps above freezing
    if so, its just condensation and or normal combustion, been humid the past few days
    when you see it below freezing, it's just a by product of normal combustion
    Lifer Expat's Avatar
    Mar 2007
    Maybe valve stem oil seals??
    Lifer DuncanMoto's Avatar
    It's a 1995 bike and you're up posting on forums at 4:15 AM.
    Be happy the smoke goes away and take a sleeping pill.
    it does go away once the engine is warm, in ambient temps above freezing...so I'm hoping it's just condensation
    it is a 1995 bike, but it's my sole means of transportation and I'm still saving my student pennies to buy a cage
    btw, Ted, I'm posting from CA! and the running condition of this bike is important, because it determines if there's a spare bike for you to ride the canyons out here
  1. For Sale - Gear | FS:Bell Star Medium white with clear/dark smoke shields
    By catahoulabuldog in forum For Sale
    Last Post: 07-24-17, 09:45 AM
  2. New Blue Smoke Guy in CT
    By peterz85 in forum Welcome and Intro
    Last Post: 05-18-11, 06:01 PM
  3. Blowing white smoke
    By ahtune69 in forum Bike Maintenance
    Last Post: 04-27-07, 08:07 PM
