2001 ZX9R with 101,000 miles. Bike has "normal' cartridge forks, not upside down.
It's not the steering head bearings. I know this for sure. They are relatively new and tightening then (even to the point that they are over-tightened) makes absolutely no difference.
Both calipers are tight and both rotors are tight.
Fork clamp bolts are tight.
Axle is tight.
Front wheel bearings are new.
Thinking the (original) fork bushings are worn out after so many miles, but open to suggestions.
What are the chances you are experiencing the brake pads shifting on the slide pins?
When you say slowing are you talking 60-30 or 30-0? The reason I ask is that my 03 zx6r has 8 brake pads for the front wheel alone and it's always been a bit clunky but more of an on off type thing that I chalked up to the hh pads I run. Basically there is little give when slowing to a stop so the bike feels "clunky", is this what you are describing? I never thought it was a big deal or worrisome but I'm subscribing to this thread because I hope it's not a bigger issue.
I don't really feel it much, I hear it. It's a sharp metallic click, about the same a when a socket head cap screw loosens suddenly.
It typically clicks as I get down below 20 MPH and am braking for a stop. Sometimes it clicks just as I am about to stop, sometimes sooner.
Mine only has 4 pads.
Stoinky- my ZX9R makes the same noise. Check and relube pads/ pins. GL!
Chains that are not adj lubed and cared for do that also....they will slap off the swing arm
LRRS EX 66
factoryeffex
My superhawk was doing the same thing back in the day. It turned out to be the fork bushings were worn and the tubes were binding instead of sliding.
I think my bike is doing that now, I always believed it was my chain because its on its way out
I ordered new fork bushings and seals. Will swap them out when they arrive and hope it sorts out the issue.
WTF? I just had my forks done, this issue was there both before and after on my ZRX. Am pretty sure it's the brake pads, but w/ those miles if your forks haven't been done recently they surely need it.
I played around with the brakes. Did not make a difference. The fork bushings have 101,000 bumpy road miles on them. I imagine they are worn some...
