Results 1 to 19 of 19
bike wont start :(
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    bike wont start :(
    2006 TTR50e
    At first i thought it was the battery. Charged it up. its reading 12 something volts right now. Then i thought it was the fuse. The fuse was showing open even though the fuse was in place. Threw a new fuse in. Then i thought it was the starter switch. Pulled the switch apart. still nothing. It doesnt even bother to try to crank what so ever. im out of ideas
    -Benjamin Franklin
    Meriden, Ct
    Re: bike wont start :(
    Fuck that thing. Give it to me for free...
    Dec 2005
    Near The Dragon
    *sigh*
    it always comes back to the basics.
    does it have spark? (pull plug, lay against head and crank) maybe it needs a plug, who knows
    does it have fuel? (did the plug come out wet or dry? did it at least smell like fuel?)
    does it have compression? (i'm going to presume it does as this is the least likely problem)
    report back your findings
    Get out while you can
    Find your own path
    Lifer lrrs313's Avatar
    Asheville, NC
    If it's not even spinning over, check wires -- ground, ignition switch, battery terminals, etc. Does it have power to the starter?
    Dec 2005
    Near The Dragon
    oh whoa sally, you need to clarify your terms.
    you mean it doesn't crank..
    try jumping power directly to the starter. if that works then the starter solenoid is suspect.
    if that doesn't work, your starter is shot.
    or you aren't describing the problem well enough..
    Find your own path
    Dec 2005
    Near The Dragon
    Quote Originally Posted by daviid View Post
    2006 TTR50e
    Quote Originally Posted by DuncanMoto View Post
    Or the starter swich is corrrrroded.
    reading comprehension, not so much, eh?
    Find your own path
    Lifer DuncanMoto's Avatar
    Quote Originally Posted by Cerberus View Post
    Well yeah, but I have seen more than one person say "I pulled the switch apart and there's no corrosion it's just a little white inside."
    Oct 2004
    Plantsville, CT
    i had a bright idea today while unloading the bike from the trailer. how about checking the engine kill switch. flipped both ways no start. disassemble switched and now it cranks.
    plug looks a bit shot. tried cleaning it up. i can get it to start shortly then it dies. although i could of sworn i had alot more gas in there when i left vir. so right now im thinking im at a air fuel ratio problem.
    -Benjamin Franklin
    Dec 2005
    Near The Dragon
    you and your air fuel ratio problems LOL
    Find your own path
    I rest my case.
    So did you remember to shut off the gas at the petcock valve?
    When you say VIR, I'm asuming you mean a few weeks ago, not a few months ago right?
    Fuel gels quickly and those jets are tiny. They clog very easily.
    Dec 2005
    Near The Dragon
    I rest my case.
    touché
    Find your own path
    Oct 2004
    Plantsville, CT
    I rest my case.
    it was the Kill Switch not the Starter switch
    -Benjamin Franklin
    Oct 2004
    Plantsville, CT
    actually it was a petcock issue. I forgot it has a on/off/res switch. and ill leave it at that
    who lets me work on my stuff?
    -Benjamin Franklin
    I kinda asumed you understood that they are in the same housing and opening it up means you check/clean both.
    At least you can laugh at yourself. Pretty funny... I'm sure most of us have done it at some point. I have just trained myself over the years to check the simplest things first no matter how unlikely it may be that that's the problem.
    Oct 2004
    Plantsville, CT
    on the ttr50 the start switch is by the throttle where the kill switch is by the left hand grip. they are 2 completely different units
    -Benjamin Franklin
    Dec 2005
    Near The Dragon
    he's done it more than once.. recently..
    Find your own path
  1. Bike wont start code _C34
    By Drewgrace in forum Bike Maintenance
    Last Post: 03-09-15, 06:48 AM
  2. bike wont start, any ideas
    By scubasteveRR in forum Bike Maintenance
    Last Post: 09-25-09, 09:09 AM
  3. BIKE WONT START
    By dj 96yzf750 in forum Bike Maintenance
    Last Post: 07-23-09, 05:49 PM
  4. Bike wont' start after winter storage
    By Bluesman in forum Bike Maintenance
    Last Post: 04-11-09, 09:50 AM
  5. Bike wont start?
    By Rclassic03 in forum Bike Maintenance
    Last Post: 08-21-08, 06:10 PM
