I bought an 03 Honda spirit 750 over a month ago. The owner said it was sat in the garage for nearly 2 years. It started right up, run with no problem. I can still ride it where ever I want it the only think wrong with it Is on the 1st gear if I go hard with it, it go up to 35mph and starting to popping it doesn't go up more. The same with the 2nd gear can go up to near 50, all the gears after that is fine.i did changed the k&n air filter, new spark plug. Didnt help.i'm currently running it with sea foam. Someone said it does take more than 1 tank to make it work. Any help?? Thanks
