This might bring up the same thoughts as dino oil vs syn, but here goes. ZX6R with ABS. Per SM no difference bleeding brakes vs non ABS model. Just ABS bike lines are longer. I used one a vacuum pump, starting with the right caliper due to routing, and then the left, then finally the MC bleeder.
Pull the lever on the pump to build vacuum, loosen nipple, close nipple before fluid runs too low or pump runs out of vacuum, add fluid. Repeat until no bubbles.
After that I repeated bleeding by pumping the brake lever a few times, hold lever, loosen nipple, close nipple before fluid runs too low or lever reaches bar, add fluid. No bubbles observed.
Is it necessary to do the manual process after using the pump? I figured pump was most efficient way to remove most fluid and manual way was best to finish the job.
Thanks,
Greg
