Results 1 to 23 of 23
Welder needed to seal puncture in gas tank
    Lifer virtualbong's Avatar
    Metrowest - MA
    Anybody skilled enough to do this type of work or can refer me to someone?
    Yowza LaRNZ's Avatar
    Oct 2004
    Tewksbury , MA
    Re: Welder needed to seal puncture in gas tank
    Martell welding in lowell or tewksbury, it's right on the line
    .:|LaRNZ|:.
    Rename your thread to 'brave welder'
    Massachusetts' Noth Shoah
    I know someone on the North Shore. PM me for a contact info.
    Go fast. Have fun. Repeat.
    Oct 2008
    Albany, ny
    How bad is it ?
    Where are you at ?
    Track bike or show piece ?
    Beat It Like A Rented Mule !!
    Legend in my own mind
    Feb 2010
    Southbridge
    Quote Originally Posted by virtualbong View Post
    i can absolutely do this for ya buddy. give me a call if interested.
    Degsy: "i never had red hair"
    Lifer FirstDuc-1098's Avatar
    Central Mass
    don't blow the shop up Richie!!
    Shit Corey says:
    Feb 2010
    Southbridge
    i weld tanks whenever i pull dents out with a dent pull system so i aint scared
    Metrowest - MA
    Quote Originally Posted by landricscustoms View Post
    Just uploaded pics of the area that I punctured. As you can see from the 2nd and 3rd pics...the puncture is behind the bracket so not sure how you would get to it. I still can't believe how idiotic of a move this was. My eagerness to get in the next track session rushed my thinking. Lesson learned.
    If you can handle something like this, can you PM me an estimate cost?
    btw. some people say to JB Weld it...thoughts?
    Feb 2010
    Southbridge
    Dont bother with jb weld. Ill take off the bracket. Do the repair and reweld it back on $130 not including if you want repainted afterwards. It would come back to you in primer at the weld location
    Ense petit placidam sandman's Avatar
    sema
    much like jb weld the pics suck.
    epoxy designed for the material the tank is made of and is gas proof would work just as good as welding or brazing.
    welding tanks is easy if you know what your dooing although your paint wouldn't be happy.
    if it's a steel tanks welding the tank with out sealing the inside after will more than likely cause the inside of the tank to rust.
    jim
    "Molon labe"
    Can you do aluminum tanks too Mr Landrics? (Say, starting with just aluminum sheet and ending with a tank? )
    Feb 2010
    Southbridge
    Quote Originally Posted by sandman View Post
    Unless the tank is left empty or fueled below the weld for a long period of time rust will not be an issue what so ever
    Feb 2010
    Southbridge
    Not quite yet... But i would love to give it a shot... Ive got aplanishing hammer sitting at my shop just dying to give it a shot.....
    Oct 2008
    Albany, ny
    For the low priceof $3.87 for some jb-weld , and 24 hrs total cure time , I would give it a try. I've had a jb weld job hold over 7yrs on the bottom side of my truck tank. Then it went to the crusher, its probable still holding.
    Feb 2010
    Southbridge
    Quote Originally Posted by BluGixxer View Post
    sure.... it Might work.. but one question comes to my mind. Is it worth the risk???? on a bike.... right above the exhaust... on a track bike....
    not to me.
    Metrowest - MA
    Hey i'll contact you this week. Thanks!
    Oct 2008
    Albany, ny
    Jb weld makes a kit for gas tanks. Its jb weld and a piece of fibreglass woven-matt, and I'm sure if it wasn't safe, they wouldn't put there name on it.
    And my cat ran next to my tank.
    Its just a sugestion for an easy fix. Sometimes keeping it simple is the best answer. K.I.S.S.
    Feb 2010
    Southbridge
    on a car... i couldnt agree more. on a bike.... eh.. not so much.
    and who you callin stupid... (k.i.s.s.) lol
    Feb 2010
    Southbridge
    you gots it buddy.
    Lifer Stromper's Avatar
    Eastern Ct
    Post whore
    Would not brazing be better for that?
    Check this out. they will also fix the dent at the same time....
    http://hawkgtforum.com/forum/showthr...t=welding+tank
    YES these are the same size tank....
    Eastern Ct
    Back in the day we would rinse and rinse
    Then stick a torch right in the filler hole just in case.
    Maybe brazing or silver solder is too old school but you could fix something like that with a propane torch yourself.
  1. Fuel tank welder?
    By Garrett in forum Bike Maintenance
    Last Post: 11-04-13, 10:15 PM
  2. radiator shop to clean/seal tank
    By gamorg02 in forum Bike Maintenance
    Last Post: 09-13-12, 03:46 PM
  3. Gas tank help needed
    Last Post: 06-26-09, 02:10 PM
  4. Welder needed!
    Last Post: 09-02-08, 07:02 AM
