Results 1 to 25 of 31
brake bleeder kits
    NOT laughing with you {~; bemused's Avatar
    Deer Island, OR
    brake bleeder kits
    decided to go ahead and get one, w/ the brake work I've got coming up. question: how well do the cheaper ones work? DK has an SBS "system" for $170... a Motion Pro Kit for $18... and a Lisle kit for about ten bucks! quite a price spread... anyone w/ any experience using the MotionPro / Lisle or some other simple kit? do they do the job?
    thanx
    jeff f
    '97 RF900R
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    yep used um all jeff
    its how offen do you do brakes & the $ you what 2 spend the pump DK has an SBS works good i used the snap on 1 looks the same 2 tell you the truth i dont even use it on the bike i just bleed um the old way . DK has an SBS works good on cages & pus save your $ get the cheap 1
    www.bostonmoto.com
    Forum Rules
    Jul 2002
    brake bleeder kits
    A company called Mityvac makes brake bleeders. I think they have two models one is made out of plastic and the other is made out of aluminum. I personally haven't used it but I think they are quite popular with mechanics. They are also rebuildable.
    Raymond NH
    brake bleeder kits
    Love the MityVac. Had one for years. Works great for setting fork oil height too.
    guy on the vintage Yamaha Rice-rocket1's Avatar
    May 2002
    New Bedford, MA
    brake bleeder kits
    I have the migthy vac and it works great. Hook it to the bleed screw, loosen it and pump away. As the level gets low in the reservoir, add more brake fluid. Keep doing it until the fluid coming out at the bleeder is clear and your down with that side. Just take note that when you use it, the mighty vac pulls enough vacuum that it will pull air in from the threads and through the bleed screw. But it isn't getting it into the lines, unless you let the level get to low in the reservoir.
    My ride's
    95 FZR 1000
    19xx DOUBLE "D"
    Lifer GadgettR1's Avatar
    New Bedford, Ma
    brake bleeder kits
    I've got a Mighty Vac also and it works great and alot cheaper than the one you quoted.
    Deer Island, OR
    brake bleeder kits
    EXCELLENT
    now... to save me some cyber running around: any idea where I can get one? aside from the website, that is?
    jeff f
    '97 RF900R
    Raymond NH
    brake bleeder kits
    A little teflon tape on the bleeder threads prevents the air bubbles.
    Any decent auto parts store should have them.
    Deer Island, OR
    Thumbs up youze guys are the balls!
    thank you one and all; y'all are the shiznit
    (I knew there was some reason I hung out here... besides the Jay-bashing, of course...)
    jeff f
    '97 RF900R
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    brake bleeder kits
    Autozone........Mityvac.....end of issue. Oh yeah Autozone actually packages it under the "OEM" label so ask someone at the store with half a brain.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Deer Island, OR
    brake bleeder kits
    Autozone... on the rack (so didn't hafta waste time looking for someone w/ half a brain )... "OEM" on the package, but pump has "Mity Vac" embossed on the side... 25 bucks (cheaper than online)...
    Thanx, Ryan
    jeff f
    '97 RF900R
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    brake bleeder kits
    No sweat, that's what makes these groups so good. Someone has encountered what you are looking for at some time. I must say though.........you're a BASTID! Found one on the first try? I looked high and low for one before I lucked out. Those things fly off the shelves with all the little Honda tuner retards on the roads now.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Oct 2001
    Bedford, MA
    brake bleeder kits
    Just wanted to say thanks, I'm going to check out Autozone when I get a chance and get one too. My brakes seem OK but the fluid is very dark colored.
    And really, the 4-cylinder car freaks actually care about their brakes in addition to their fart sounds?
    Ben
    Re: brake bleeder kits
    BACK FROM THE DEAD
    What are people using for brake bleeding kits now a days?
    Haven't done a brake job before so this will be my first time (thats what she said).
    Any noob friendly, dummy proof kits?
    TWINS! xrocket21's Avatar
    Central Maine
    I dont think im using the mityvac right cause I cant get it to work for shit
    Oct 2009
    Xrocket21,
    How exactly is it not working? Did you forget to turn the bleed screw open? Did you forget to open the reservoir top?
    Quote Originally Posted by Kazinator View Post
    speed bleeders and tubing from Street & Comp. dont waste your money on a miti-vac
    EX 105 : CCS Atlantic, Mid Atlantic, South East, Florida, and WERA
    Sponsors: Motul, Michelin/STS, K&N, Woodcraft
    I don't even bother with speed bleeders. I just put a clear rubber tube on the bleeder nipple, crack it open then squeeze & release the lever really fast.
    true, but speed bleeders are helpful for new people that dont have a good feel for bleeding brakes yet.
    Central Maine
    Quote Originally Posted by qqac View Post
    Xrocket21,
    reservoir open, bleed screw upen
    it just wouldnt pull any fluid, and I had plenty of vac
    I ending up just pumping the shit out of them till I got fluid.
    Maybe it will work better with brakes that arent being bled for the first time, like when changing the fluid. When I was using it, the calipers and lines were empty. Thats the reason I bought it, was because I couldnt get them to bleed by hand so I bought the mityvac. It didnt help.
    Oct 2009
    Calipers and lines empty explains a lot. You needed to suck the air out of all that space and draw the fluid through it, that's why it took extra long.
    Central Maine
    heh, I was trying to use it to speed up the process and it wasnt working.
    I have a vacuum bleeder and never got it to work correctly. I've had good luck with manually bleeding brake and hydraulic clutch lines.
    Jim sucks.... so I usually ask him to come over & suck on my bleeder nipples.
    Way better than a mitty vac
    Quote Originally Posted by bemused View Post
    Was at autozone today buying new turn signal bulbs after I put the bike on the ground yesterday.
    Asked about this bleeder. They had two in stock. Bottom shelf in the tool section in my store. Price is now $35. Says 'mityvac' right on the side. Seems like a heckuva deal..
    I didn't have the bags on the bike, so no space to take one home.
  1. Speed Bleeder Screws
    By pontifex in forum Bike Maintenance
    Last Post: 06-10-14, 09:07 PM
  2. Need to borrow RFI brake bleeder
    By eboos in forum Bike Maintenance
    Last Post: 07-26-10, 05:02 PM
  3. Caliper bleeder valve odd leak?
    By Billy in forum Bike Maintenance
    Last Post: 02-20-07, 11:19 AM
  4. lukesracing.com - pistons, rebuild kits, bore kits etc...
    Last Post: 11-16-06, 09:12 PM
  5. who needs a speed bleeder when...
    Last Post: 04-17-05, 05:41 PM
