Results 1 to 18 of 18
Tire balancing...
    Jun 2005
    Tire balancing...
    So, I mounted up a new set of Powers on Saturday. My question is about balancing. The front took about 50 grams to balance. I even took it off the stand, broke the bead, spun the tire on the rim and re-balanced it.
    I've never had to use more than 20 grams before. Is using this much weight relatively common and I've just been lucky in the past? (the rear only took 5 grams).
    Dec 2003
    Ma
    Tire balancing...
    Did you line up the dot opposite the valvestem?
    Used race tires are the only I usually see needing a ton of weight to balance.
    Tire balancing...
    Sounds like something's up. Like you, I have never used more than 3/4 of an ounce. 50 grams is about 1 3/4 ounces.
    derek
    Jun 2005
    Tire balancing...
    The front didn't have a dot... just a bar code that I figured was probably the heavy spot. I put that opposite the stem... When it came out needing so much weight, I figured I should spin the tire on the rim just to make sure what I thought was the heavy spot was actually the heavy spot... so I put the bar code at the stem and it made it worse (so I guess I was right the first time). I broke the bead (again) and spun it back, but it's still around 50 grams.
    The OEM tire that I pulled off didn't have any weight at all, so I suspect that the rim is cool...
    Maybe I should try to balance it without the rotors to rule them out?
    Tire balancing...
    That won't buy you miuch unless you want to ride with no rotors LOL.
    I would see if you can check the wheel and rotors for runout. Also, try spinning the wheel really fast for a few spins to warm up the grease in the bearings. Maybe you have a tight spot in the wheel bearings or some corrosion on the axle?
    Of course, it might just be that the tire is on the hairy edge of the factory balance specs.
    derek
    Jun 2005
    Tire balancing...
    True, true... I was thinking that perhaps there was a heavy spot on the rotors that was adding to the problem... ie: if it only takes 10 grams without the rotors... I could potentially rotate them accordingly, but I think it's a long-shot.
    The balancing stand I made uses 4 de-greased, no seals, lightly oiled ABEC 5 bearings (kind of like the one in the pic), so grease/seal drag on the wheel bearings shouldn't be a factor.
    I'm suspecting that the tire may just be on the hairy edge... Ah whaddayagonnado. I'm just not too stoked on having two large weights on my front wheel that could potentially turn into missiles if they came loose at high speed .
    Tire balancing...
    It doesn't look pretty, but I prefer to put duct tape over the weights for the first couple of weeks until the glue really sets on the weights.
    Just put half the weights on one side and the other half on the other side, then it looks from either side like you only have 3 or so small weights each side.
    derek
    Lifer Karaya One's Avatar
    Springfield, Mass
    Tire balancing...
    Michelin's do not have balance dots. You are balancing the rim with a Michelin.
    Check out my eBay store!
    Dave - Motorace - Michelin
    Senior Member LiononaLeash's Avatar
    Oct 2005
    Tire balancing...
    +1 on Michelins not having Dots.
    I put some Powers on the other day... Had me wondering... All is well balanced now
    Jun 2005
    Tire balancing...
    Good to know...
    Does that blue dot on the rear bead signify something? (just curious).
    KB KB's Avatar
    Manchester NH
    Tire balancing...
    I have been mounting my tires and numerous "others" tires for years now and we gave up on the balancing bullshit.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    FUCK OFF Hardcore's Avatar
    Jul 2005
    norwood ma
    Tire balancing...
    nice timely reply numnut!!
    this post ended a month ago!
    Ense petit placidam sandman's Avatar
    sema
    Tire balancing...
    same here. i just line up the dots and leave whatever weights that are on the rims where they are.
    i've never had any vibrations.
    jim
    "Molon labe"
    KB KB's Avatar
    Manchester NH
    Tire balancing...
    Here is another timely reply:
    GO FUCK YOURSELF
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Raymond NH
    Tire balancing...
    I was going to write that I never bother with balancing, but I was forced to balance the new front Continental Road Attack on my 9R yesterday. It was pretty far out of balance and vibrating at highway speed. All better now.
    Springfield, Mass
    Tire balancing...
    The Road Attack is a very underrated tire. It is a very good piece of rubber.
    The new Sport Attack is even better!
    Raymond NH
    Tire balancing...
    On my second set. I like 'em. How much do you get for a 120 70 17 and a 180 55 17?
    Springfield, Mass
    Tire balancing...
    Motorace is a distributor - I get in trouble for selling street rubber direct to the customer. Dealers hate that.
    Sorry.
  1. tire mounting and balancing near franklin
    By gamorg02 in forum General Bike Related
    Last Post: 10-03-10, 07:22 PM
  2. tire mounting/balancing
    By darkduc7 in forum Vermont Events
    Last Post: 06-21-10, 09:15 PM
  3. Tire mounting and balancing - southern NH
    By Fitz in forum Pit Area
    Last Post: 07-09-08, 07:08 PM
  4. WHO?: Tire Mounting and Balancing
    By Suf Daddy in forum General Bike Related
    Last Post: 07-16-06, 09:31 AM
  5. Tire Balancing
    By KB in forum Bike Maintenance
    Last Post: 05-04-04, 07:20 AM
