I put on a full set of Spiegler stainless lines, and bought speed bleeders for the front and rear. Well the rear was the wrong one, so stock went back in. I got the rear done then moved onto the front, bled the master, then each caliper. The banjos are tight, no leaks. I tapped the lines a lot to try and knock any bubbles lose.
the problem is, bubbles are still coming out of the bleeders in the front. Tiny bubbles, some larger. I'd not have even seen them I bet if I wasn't shining a flash light into the tube.
So I used almost half a liter of RBF600, is this normal ? I didn't think it would take so much fluid. I have to get another bottle and continue I guess.
