Results 1 to 6 of 6
Brake Caliper Pad Mounting Pin Stripped
    Member Drewgrace's Avatar
    Everett, MA
    Well I did it this time., while trying to remove a Pro Bolt Pad Mounting Pin, it freaking stripped it. So I tried everything to get it loose, and destroyed it. So now I guess I'm going to have to replace the caliper. It's a K8 GSXR1000, so it could used an upgrade or replacement. Should I get a used stock one? Are they reliable? Should I replace both if I do? Do I get an upgrade, and what are some recommendations? Got a trackday coming up in a few weeks, and really don't want to miss it.
    Lifer NPDCPA's Avatar
    Mar 2011
    Re: Brake Caliper Pad Mounting Pin Stripped
    Those calipers should be cheap on eBay. Aren't they 100mm spacing? If so, a variety of calipers should fit. I thought I saw something about Yamaha calipers on GSXR forks being a hot set up with the west coast SV race guys.
    so different forms of screw extractors all didn't work?
    I had the same thing happen on a set of 06 calipers...had a machine shop remove it. WAS A HUGE PIA..
    If you going to replace them go with either 06 and up R6 calipers with the spacers or a the direct and huge upgrade is the 09 Mono block calipers... with the Brembo 19RCS it will toss you over the bars and no fade ever.... OEM master is the week spot also so...
    RidersDiscount usually has a killer price on the Master also...
    These..
    U 09 10 11 12 13 14 Suzuki GSXR1000 GSXR1000R Front Brake Calipers Tokico | eBay
    I have a mint set of pins and bolts and some other GSXR break stuff you can have if needed......
    happened to me on my 06 600. the Pro Bolts are super thin, so it's easy to strip if you're using a 12 point socket.
    i used pliers and got the pin loose by pinching a side and rotating the whole thing
  1. Ex500 Front Brake Caliper
    By Aaron377 in forum Pit Area
    Last Post: 09-27-14, 05:53 PM
  2. Wanted - Parts & Tools | 1st Gen SV650 rear brake caliper
    By pontifex in forum Wanted
    Last Post: 06-16-14, 11:06 PM
  3. Help with brake caliper pistons
    By throttlejunkie in forum Bike Maintenance
    Last Post: 06-28-12, 05:10 PM
  4. wtb \\\\\ BRAKE CALIPER /////
    By Bandit12k in forum Wanted
    Last Post: 03-07-10, 11:24 PM
  5. WTB 6 pot brake caliper
    By Bandit12k in forum For Sale
    Last Post: 12-07-09, 10:17 PM
