Results 1 to 9 of 9
brake fluid
    Senior Member double agent's Avatar
    Sep 2002
    acushnet - yates replica
    brake fluid
    dot 4 or dot 5
    time to change and dont know what to go with?
    any sug.
    If money is the root of all evil,
    why do churches beg for it?
    brake fluid
    dot4 is more than good enough, and cheaper than dot5... plus it's easier to find
    Just Registered
    Is it not obvious?
    brake fluid
    dot4 unless you're gonna bleed the system and drain it extensively before going to 5, or your bike came with it
    www.gpsdiscussion.com
    motorcycleaddicts.org
    Sep 2002
    brake fluid
    I say this only because one of the guys I ride with hates dot5 mabey he had issuses useing it but he told me that dot5 is harsh on rotors. (?) I didnt get it ether. anyway I use it (dot5) and never had a problem. I told him to change his pads more often.
    brake fluid
    Dec 2003
    Ma
    brake fluid
    I hear there's DOT 5.1 that isn't silcon based? (whatever base) like the 5.0 but has the same characteristics. DOT 4 is more than good enough.
    Mar 2004
    woonsocket ri
    brake fluid
    ........ he told me that dot5 is harsh on rotors. (?) ........
    I would definately trust this guy's judgement He sounds very knowledgable
    brake fluid
    yeah, 5.1 is silicon based, but 5.0 is sand based... it seeps through the caliper piston, through the pad & grinds away at your rotors
    what a goon
    Aug 2004
    NH
    brake fluid
    Dot 3, 4, and 5.1 are glycol based and Dot 5 is silicon based. Do not mix the two. Glycol based are hygroscopic (absorb moisture) while silicon based does not, however, the o-rings and gaskets used on each may not be compatible with the other.
  1. brake fluid
    By scubasteveRR in forum Bike Maintenance
    Last Post: 03-08-12, 07:01 AM
  2. Brake Fluid
    By oVTo in forum Bike Maintenance
    Last Post: 05-26-09, 08:35 AM
  3. Brake Fluid still good?
    By akira700 in forum Bike Maintenance
    Last Post: 08-22-07, 09:03 PM
  4. Brake fluid etc.
    Last Post: 11-11-05, 02:58 PM
  5. brake fluid
    By bemused in forum General Bike Related
    Last Post: 03-14-03, 11:17 AM
