Results 1 to 23 of 23
Exhaust wrap
    Lifer Pittenger5's Avatar
    Austin
    Exhaust wrap
    Seeing as I'm an idiot and keep burning my leg on the exhaust, and I'm far too stupid to simply stop touching the exhaust, I was thinking of using some exhaust wrap on the exposed part of the midpipe. But being that I ride a big single, I dont want to smother it and not let a lot of heat come off. So how much does exhaust wrap keep the heat in, and is there any better suggestion.
    Zip Tie Alley #505
    Lifer R1's Avatar
    Somewhere you dont know...
    Re: Exhaust wrap
    you could always get your exhaust ceramic coated
    Nat Pixon! noxin's Avatar
    Apr 2008
    Boston, MA
    Re: Exhaust wrap
    or put a heat shield over it
    Re: Exhaust wrap
    That's a titanium header, yes? If so, you do not want to wrap it as that'll guarantee more cracks.
    Re: Exhaust wrap
    You will catch fire for sure.
    I have a roll of wrap if you need it
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Ma
    Re: Exhaust wrap
    Since no one else mentioned it. Heat wrap does not reduce the heat of the pipe all that much. Yes it keeps the heat in the pipe longer, but I still melted a pair of boots on my wrapped pipes. A heat shield will do better.
    jmo
    I like cats.......but I can't eat a whole one by myself.
    Lifer R1's Avatar
    Re: Exhaust wrap
    hence why i mentioned the ceramic.
    also if your pipe has a catalytic converter of baffles in the slip on then they are building up excess heat.
    you could also use heat reflective tape.
    but the wrap will reduce the radiant temps but will increase the actual exhaust temps.
    IE it will not emit heat as far as open metal but it will still burn to the touch if not become hotter.
    and i also found there is a rattle can ceramic coating that you can spray over the fiberglass exhaust wrap that will aid in reducing the temps.
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    Re: Exhaust wrap
    I like the wrap. I have it on my mid pipes and no you dont want to grab it because its still hot, but it wont peel your skin off like a bare pipe will. It does increase the temp on your exhaust coming out the tail pipe because the heat does not dissipate prior to that. I have also heard that heat wrap can promote rusting because as the pipes cool, the wrap retains moisture that is then held against the pipe. I have mine wrapped and spray coated with sylicone high temp paint. looks good and more importantly does not burn my flip-flops.
    Austin
    Re: Exhaust wrap
    I shoulda mentioned this is on my KTM 690SMC, not the race bike. But there are heat shields but they just dont extend far enough forward, and I tend to bump the exposed pipe now and again at stop lights and stuff. I dont need anything that will keep it cool to to the touch or anything, but just keep me from burning myself on the occasional bump.
    Zip Tie Alley #505
    Apr 2008
    Boston, MA
    Re: Exhaust wrap
    put more heat shields on further up the pipe.
    Dec 2005
    Near The Dragon
    Re: Exhaust wrap
    I'd say ceramic coat inside and out
    Get out while you can
    Find your own path
    Austin
    Re: Exhaust wrap
    Quote Originally Posted by noxin View Post
    How does one go about doing that.
    Zip Tie Alley #505
    Re: Exhaust wrap
    http://www.elineaccessories.com/Shop/PipeGuards.asp
    Re: Exhaust wrap
    quick question guys, how can i create a new thread?
    Lifer CMG241's Avatar
    Windham, NH
    Re: Exhaust wrap
    Been wrapping mine for years, if you do your be sure and spray paint with the protective paint, if not it won't last more than a season. does it reduce the burn factor on skin and shoes? yes but its still hot. It does increase the combustion chamber temp but some bikes like that so I have read.
    Re: Exhaust wrap
    I'm in the same boat with my SMC. All my rain and textile pants have holes now!
    Re: Exhaust wrap
    Stop riding foot out!
    Seriously though, get a little heel guard or something & throw it on there.
    Re: Exhaust wrap
    Negative
    It's right where the pipe bends, making a non custom heat shield awkward.
    Austin
    Re: Exhaust wrap
    Yah, its this area. My pants are all burned, and when you put your foot down it tends to hit.
    Zip Tie Alley #505
    Lifer akira700's Avatar
    Apr 2005
    in the city
    Re: Exhaust wrap
    STOP RIDING IN SHORTS!
    Guys what about wrapping your legs ?
    Well here's what I did.
    Wrapped the pipe plus put that metallic heat insulation tape
    on the back of my heat shields. Its totally bearable now.
    Before its sucked at red lights something fierce.
    As I understand it wrapping your pipe also helps performance a bit by
    allowing the hot gases freer passage out the back.
    2008 Honda CBR 600RR
    dad,husband,motorcyclist JoeT's Avatar
    Broomfield Colorado
    Re: Exhaust wrap
    I did it and had to rejet after. Just something to keep in mind
    ( I have 1/2 a roll left over if you want it)
    currently just an oldman bike, but searching for my new ride
    .Sold to a guy in Mississippi searching for a new ride.
    Re: Exhaust wrap
    do it...wear gloves and long sleeves..and your supposed to wet the wrap before you apply it. your only doing a small section so i wouldnt worry about jetting and shit. whats the worse that could happen? you keep burning your leg?
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    Re: Exhaust wrap
    its also gonna smoke like hell for the first few minutes. if u dont have it done by the classic, ill bring some up with me
    -Benjamin Franklin
  1. For Sale - Parts & Tools | Lightly Used Rinehart Exhaust & Stock Exhaust 2020 Street Glide
    Last Post: 01-03-21, 03:09 PM
  2. Suggestions on Exhaust wrap and Heat Shield Cloth
    By tsorfas in forum General Bike Related
    Last Post: 04-10-15, 01:37 PM
  3. am 220 Wrap up
    By bdawkins20 in forum Race Reports
    Last Post: 09-16-11, 03:03 PM
  4. Replies: 9
    Last Post: 08-02-08, 01:19 PM
  5. It's a wrap!
    Last Post: 07-28-07, 01:13 PM
