Page 3 of 3 FirstFirst 123
Results 51 to 61 of 61
brake fluid
  1. #51
    Re: brake fluid
    I drop from 4th to 3rd, and in pics of most guys, their front ends are always slammed coming into the bowl.
    I think Loudon is as good as any for evaluating brakes (but I think it's being wayyy overthought), as there's lots of trail braking and not many long periods with no brakes at all.
    Yeah I was gonna say... I dunno about the others, but I brake pretty damn hard coming into 1, into 3, into 6, into 9 (yes, 9) and into 11. Granted it's not a very long time period of braking, but I'm near-max braking in each of those sections for at least a short while.
    But maybe I'm not as fast as I thought.
  2. #52
    Just Registered Doc's Avatar
    Jericho, VT
    Re: brake fluid
    Explain the 9 thing. Do you not let off until after the tree house? (Serious question).
  3. #53
    Lifer Stromper's Avatar
    Eastern Ct
    Re: brake fluid
    If you had brake fade then caliper rebuild is in order making sure nothing but the highest temp fluid is totally filling the the caliper. The part that gets hot.
    You also after a fade session try spinning the front wheel and see if ther is significant brake drag.
    I dont know but I assume that long life is not on the race fluid radar
    Primer for the rest of us
    http://www.gomog.com/allmorgan/brakefluids.html
  4. #54
    Re: brake fluid
    You should be passing the tree house and hitting the ripple bumps at full throttle...
    Re: brake fluid
    WFO from 6 to past the tree hizzy, especially on a lw or ulw bike.
  6. #56
    May 2011
    Northern MA
    Re: brake fluid
    I'm thinking about installing a stainless steel cable for the front, my first time. Not sure I understand this part (abbreviated quote)...
    Quote Originally Posted by DuncanMoto View Post
    Don't switch out to speed bleeders with a disconnected or empty line.
    Then drain fluid from lines and install your new lines.
    Once you're fully bled system then button up the reservoir cap and switch out to the speed bleeders ...
    "Fully bled" I'm guessing means the brake line is filled with new brake fluid (it is not empty when installing the speed bleeder), right?
    Couple more questions, once we clear up this first question.
    Thanks.
    who knows
    Re: brake fluid
    Marc, that is correct. You need to have the system full of brake fluid before putting the speed bleeders on. regular air doesn't create enough pressure to activate the valve on the speedbleeders.
    if you're not changing the brake lines or totally draining your system you can just put the speedbleeders on and pump away while adding fluid in the resiviour so you don't suck in air
    May 2011
    Northern MA
    Re: brake fluid
    Thanks Steve!
    Lets say I replaced the cable. The new cable is dry (full of air) and using the conventional bleeder. I imagine the sequence [open bleeder][pull brake][close bleeder][release brake] would be repeated 1000+ times (fool's errand). This is where the mityvac keeps you sane: [build up 20+ lbs pressure][open bleeder][add brake fluid, preventing air entering the master].
    Just looking to confirm if I understand the hows/whys.
    --Marc
  10. #60
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Re: brake fluid
    pull brake lever before opening the bleeder. you're only gonna have the bleeder open for a second cause the lever will go back to the bar. quickly close the bleeder so you don't suck air back in. ideally close the bleeder before the lever hits the bar so that you're keeping pressure.
    Re: brake fluid
    Can't you just start with a gravity bleed?
  1. Brake Fluid
    By oVTo in forum Bike Maintenance
    Last Post: 05-26-09, 08:35 AM
  2. Brake Fluid still good?
    By akira700 in forum Bike Maintenance
    Last Post: 08-22-07, 09:03 PM
  3. Brake fluid etc.
    Last Post: 11-11-05, 02:58 PM
  4. brake fluid
    By double agent in forum Bike Maintenance
    Last Post: 04-23-05, 03:56 PM
  5. brake fluid
    By bemused in forum General Bike Related
    Last Post: 03-14-03, 11:17 AM
