Results 1 to 25 of 47
Brake pads
    Apr 2012
    Brake pads
    After 5 days on new brembo z04 pads, I am noticing a real decrease in stopping power. How many days are you guys getting out of a set?
    Is this a short time for pads? Could my problem be glazing?
    Also, any recommendations for a great pad?
    Apr 2011
    NH
    Re: Brake pads
    1/2 to 1 season on the front stock Brembo pads. DP's about the same and the SBS's that are in now seem to be wearing the same as the others. Three seasons on the rear and they're still what Ducati put in in 04.
    Tim
    LRRS #44
    Superbike Services 44
    Re: Brake pads
    Quote Originally Posted by Jewcati View Post
    Carbonne Lorraine C60s thus far are the best I've experienced.
    EBC HH - yuk
    Vesrah RJL - mmm, tasty.
    CL C60 - awwww yeahhh. giggity.
    Re: Brake pads
    add Performance Friction to Pete's list. they're sold from Street Comp.
    Re: Brake pads
    I Like the Performance Friction compound 07. They need heat, but work awesome, progressive bite is how I would describe it. Keeps the front end nice and settled.
    Massachusetts
    Re: Brake pads
    I've had super good luck with Vesrah's (both RJL and XX) pads for many years. Power on demand - no warping or bending of the backing plates.
    Re: Brake pads
    Another vote for the CL60's You can get them from spieglerusa.com. I was forced to use a set of Performance Friction pads last season and they didn't give anywhere close to the stopping power that the CLs give me.
    In the PF's defense, it might have been due to having CL material on my rotors and I didn't have a lot of time to bed in the PF pads.
    Re: Brake pads
    I like my EBC EPFAs, but it seems I might be in the minority.
    Re: Brake pads
    Quote Originally Posted by Woodcraft View Post
    This.....and have the rotors sent to truedisc LLC and cross hatched/trued and you will be good.....
    Apr 2012
    Re: Brake pads
    How many days are you guys getting on the vesrah rjl?
    The brembo z04 that came in my bike were new. At 300 a set I expected them to last a lot longer!
    They are not close to the markers, but the stopping power is seriously decreased. Any thoughts?
    Re: Brake pads
    its seasons now for me.......breaks are still nasty and will flip the bike if im not carefull
    May 2010
    Somersworth, NH
    Re: Brake pads
    Really loving the DP pads i have now great stopping power and really good feedback from them too
    Senior Member MFChop's Avatar
    Apr 2014
    Nashville, TN
    Re: Brake pads
    Another vote for CL60s!
    Got mine from www.sportbiketrackgear.com
    Re: Brake pads
    Try scuffing your rotors with a scuff pad. Scuff around going diagonally in one direction, then the other.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Re: Brake pads
    this.
    been running Vesrah SRJL-17s for a couple years now. I have a set of XXs to use when I need them. not sure if I screwed up when ordered if were mailed the wrong ones but I wanna try them anyway.
    really depends on how often you're riding and how hard you are on the brakes. Shawn says he gets a season. but I get maybe 3/4 of a season. I'd say he uses them more/harder per lap than me but I rode more often (more track days and more races).
    3M makes these resurfacing discs. I'd go real easy with them though. I've used a paint stripper disc drill attachment in the past. worked great to clean any residue from old pads off. http://3mcollision.com/3m-roloc-brak...pack-1410.html
    Re: Brake pads
    i used to go through 2.5 sets of pads a season. but that's 40 races, 4(ish) track days, and 3(ish) friday race practice days.
    what i would suggest doing is....measure the material when you buy a new set of whatever you get with digital calipers. every 2-3 track days, take the pads out and measure how much material is left. while the pads are out, it wouldnt hurt to clean your caliper pistons
    Apr 2012
    Re: Brake pads
    So then they are most likely glazed...anything to do to save the pads or just replace?
    Senior Member fromario's Avatar
    Apr 2008
    Re: Brake pads
    You can try to save them by doing this:
    I also scuffed the pads
    I did this on my street Monster and am still riding on those pads and rotors a year later with no problems
    1995 Honda RVF400
    2003 SV650 Superbike ...eat a dick Scottie
    2007 Ducati S2R1000
    Re: Brake pads
    if they are glazed (which they probably aren't), then you can scuff the pads and rotors up. then break in everything properly
    Meriden, Ct
    Re: Brake pads
    I finally got a chance to run DP's new race pad this past Monday.
    Color me impressed.
    Apr 2012
    Re: Brake pads
    If they aren't glazed, what would cause the lack of power compared to the first few times I used them?
    I don't think it is a fluid issue, as the lever doesn't feel mushy, has lack of power at the end which cause me to blow T1 twice on Monday.
    Re: Brake pads
    Too much unobtanium? You can't eliminate reasons on the internet. Take the pads out and inspect for glazing. While you're at it might as well scuff up the pads and rotors and start again. Pads, like tires tail off in their effectiveness with use. Could be as simple as that. Some brands/compounds are longer lasting that others. I would try cheaper pad recommended her in personally.
    Junior Member khanlon's Avatar
    Feb 2009
    Norfolk, MA
    Re: Brake pads
    I had a similar issue last year...turns out I was not completely closing the throttle when braking into turn 1 Sounds stupid, but you may want to make sure you are rolling all the way off if you can't find a problem with the brakes.
    Branford CT
    Re: Brake pads
    DP all the way
    #277
    Re: Brake pads
    I really liked the PF 07 compound.
  1. Brake pads
    By Garandman in forum General Track Day Talk
    Last Post: 07-29-19, 07:15 PM
  2. New EBC Brake pads FA 322/4HH
    By 03Worc9R in forum For Sale
    Last Post: 07-04-12, 05:41 PM
  3. need new brake pads
    By DaveZX6r in forum Bike Maintenance
    Last Post: 03-09-12, 01:19 PM
  4. Brake Pads
    By chris275275 in forum Bike Maintenance
    Last Post: 02-25-12, 12:59 AM
  5. New Brake Rotors = New Brake Pads?
    By highsider in forum Bike Maintenance
    Last Post: 03-27-07, 10:39 AM
