Results 1 to 14 of 14
pre-season maintenance
    Just Registered kermita's Avatar
    Mar 2007
    RI
    Question pre-season maintenance
    The 636 is currently in my basement with the wheels off (getting some new Pilot Powers) and stripped of body work so that I can check fasteners and do some cleaning. So my question is....what color loc-tite should be used and where? Also, is anti-seize the best thing for the front/rear axles? Any other things I should be looking at before putting her back together again?
    TIA
    -kim
    drz400sm
    http://farm3.static.flickr.com/2473/3532494258_79ceb54614.jpg
    Just Registered
    Is it not obvious?
    Blue loctite tastes the best, and it's your friend...just don't saturate the threads with it, doesen't take much to do it's thing.
    Don't use red anywhere unless you never want to take that nut or bolt off again EVER, almost.
    Little bit of anti-seize isn't a bad idea I would guess, but I personally don't use it.
    Feb 2004
    Bellingham, MA
    Use grease on the axles, don't use loctite any where. A properly torqued bolt will not come loose and the loctite will gum up the threads. There are a few spots where loctite is needed, but not any place you will be checking. Maybe we need to do a "Basic Maintenance" seminar?
    Member ejoy1220's Avatar
    Mar 2007
    Amherst, MA/Carver, MA
    If I had the wheels off, I would make sure the chain were lubed well, and the bearings were nice and greased, but on a new lower mileage bike it shouldn't be that big of a deal.
    R1
    KB KB's Avatar
    Manchester NH
    Quote Originally Posted by l3uddha View Post
    that seminar would be a great idea!
    p.s: do you mean grease the length of axle, or just the wheel bearings?
    You said "grease the length"
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Lifer union's Avatar
    Blackstone, MA
    Ill be there. I might as well pack a suitcase. It seems I might jsut move in.
    James
    Lifer Wishbone's Avatar
    Jul 2006
    do the seminar pete, it will help all us learn. especially me cause im a moron
    plus i like the pizza
    Mar 2007
    RI
    thanks for the input. any particular type of grease for the axles?
    -kim
    drz400sm
    Mar 2007
    RI
    sounds good to me. the more i can learn about maintenance the better.
    -kim
    drz400sm
    Lifer reiobard's Avatar
    Jul 2005
    Bennington, NH
    A seminar would be great!
    Feb 2004
    Bellingham, MA
    grease the axle with a light coating of a good water proof grease. It keeps the axle from oxidizing and cold welding it self to the bearings and the distance collar. I'll put some thing together for next month.
    Senior Member nerijusj's Avatar
    Somerville, MA
    Quote Originally Posted by kermita View Post
    TIA
    Well, first part of your question was answered. As to which bolts need to be loctited- you will see some residue on a bolt tread when you remove a bolt. These were loctited at the factory.
    ZX10R
    Ned
    Mar 2007
    RI
    The worst example I've seen of loctite residue was when I took out the bolts for the bar ends. The bolts were completely full of red locktite and I imagine that the inside is as well. The funny thing was that it was nothing at all to get those bolts out. Can you actually use too much loctite and counteract its original purpose? And what's the best way to clean loctite residue?
    -kim
    drz400sm
    Somerville, MA
    Yes, the factory stuff is not blue. It doesn't mean that they are using red (permanent) loctite though. Might be another brand and that's why it's different color. Not sure about cleaning that residue off of bolts, never bothered.
    ZX10R
    Ned
  1. F4i Maintenance
    By Kazinator in forum Bike Maintenance
    Last Post: 05-25-12, 01:01 PM
  2. Need help with maintenance..
    By Ecooke21 in forum Bike Maintenance
    Last Post: 03-03-07, 02:37 AM
  3. What maintenance have you done?
    Last Post: 02-20-05, 07:12 AM
