Page 2 of 2 FirstFirst 12
Results 26 to 42 of 42
Broken bolt
    Re: Broken bolt
    Quote Originally Posted by Woodcraft View Post
    Just as a note as I follow this thread, motor mount bolts do not need or want Loctite. If anything, they need never-sieze on there for the previously mentioned dis-similar metals reason. When properly installed, they will not work loose by themselves. In the event that a bolt breaks in a fall, they are infinitely easier to get out if there is not Loctite gumming up the threads. If you have used Loctite, I would suggest using a propane torch to melt the loctite just prior to attempting any extraction (EZ-out or similar intalled and ready to go).
    Lots of good advice on getting the first EZ-out removed on this thread. Worst case here is the the bolt gets drilled out until all the garbage is gone, trying again with a new EZ-out and then heli coiling the threads. Fun stuff.....
    Thanks Eric. Good to know about the never seize.
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Re: Broken bolt
    Quote Originally Posted by Eric Baker View Post
    go really slow with plenty of lube.
    That's what she said!!!
    Re: Broken bolt
    Eric, don't the slider instructions say to use blue loctite?
    I'll never seize them going forward.
    Wirelessly posted
    Those front motor mount bolts on the gixxer have a lock bolt on them. They should never have loctite on them.
    Re: Broken bolt
    so Degs, what's the next plan? drop the motor, try heat, drill out that EZ out and try again?
    Wirelessly posted
    Take front fairing off and use a drift to try to knock out the stuck EZ out. Then drill out the bolt to get a bigger EZ out in there I think.
    May 2010
    Somersworth, NH
    Re: Broken bolt
    pee on it... problem solved! serioiusly tho had ez outs break on me in the past es no bueno
    Massachusetts
    Re: Broken bolt
    You made me go back and read all of the instructions we ever made for sliders......and I was glad to see that we have never asked riders to use Blue Loctite. In the a couple of the more recent ones we added the Never Sieze recommendation as well. I've got someone on updating all of them at present.
    Re: Broken bolt
    thanks Eric. i know the rearsets say to use blue loctite, and i thought the sliders did too.
    i ordered a new slider bracket & puck on Monday asking to get it by Wedneday, but it sounds like I obviously wont be installing it this week.
    May 2010
    Somersworth, NH
    Re: Broken bolt
    quality control at its finest!!
    Nov 2008
    Framingham, MA
    Re: Broken bolt
    Quote Originally Posted by RIZXVIR View Post
    One could it call it quality control but one could also say "idiot proof it" - sorry but no harm is intended at anyones's direction.
    Massachusetts
    Re: Broken bolt
    I've been told that you cannot make anything idiot proof, only idiot resistant.....
    Loctite on a motor mount bolt....not too big a mistake. If you guys want some stories, I've got plenty after 16 years of selling aftermarket parts.....some people shouldn't be allowed to touch tools - ever.
    Nov 2009
    Bristol County
    Re: Broken bolt
    I'd love to hear them. All of them. Waste as much time as you like typing. Start a thread?
    nedirtriders.com
    Wife calls me a member Svenny's Avatar
    Mar 2012
    Seekonk MA
    Re: Broken bolt
    2008 Fisher-Price Kawi 12VDC
    Exide hi-performance battery
    Frost-King duct tape reinforced steering damper
    Topps "Garbage Pail Kids" custom graphics
    Lifer SprintPoser's Avatar
    Apr 2002
    Central MA
    Re: Broken bolt
    Idiot resistant doesn't work either, they keep producing craftier idiots.
    BTW, I have a set of EZ-Outs. They are used as a paperweight because as you screw them in with their left-hand spiral "fluting", they spread-out the body of the screw. That makes it even harder to get the broken screw/bolt out. If I have a broken bolt to remove it I get the offending assembly onto the Bridgeport and get it out using a variety of solid carbide tools, left hand drills, picks and other stuff as the situation can vary.
    If in the field and this is not practical, use these spline drive type of screw extractors. They are far better!
    http://www.toolfetch.com/Category/Bi...ets/AP9447.htm
    Douglas Ma
    Re: Broken bolt
    You can also try a left handed drill bit or a grabit screw extractor or I saw this tool but ive never tried it.http://www.youtube.com/watch?v=FkIH7...eature=related
    Posting Freak boloson's Avatar
    Oct 2007
    Re: Broken bolt
  1. Broken stator cover bolt....
    Last Post: 09-21-12, 06:30 AM
  2. Broken down in Medford. Help!
    By Aimy77 in forum General Bike Related
    Last Post: 06-15-10, 10:22 PM
  3. it's broken
    By Evil_Weasel in forum Pit Area
    Last Post: 05-08-07, 10:11 AM
  4. Broken bike
    By theothersean in forum Dirty Bastards
    Last Post: 08-03-05, 05:49 AM
