Results 1 to 8 of 8
can't get an old bike started.
    Member throttlejunkie's Avatar
    Apr 2006
    Jacksonville
    Question can't get an old bike started.
    So I am trying to revive an '82 CB 750 for my gf, I've got spark, fuel, and compression and the timing is as close as I can get it. the most it will do is sputter for about 2 seconds and then nothing. I've tried with and without the air filter in case it wasn't getting any air but there isn't any difference. I know it runs, I had it running a year ago but couldn't get it to idle. I was going to try and sink the carbs this weekend but without it starting I can't do that. I'm at a loss at this point, an suggestions would be greatly appreciated.
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: can't get an old bike started.
    Hard to know without being there. If it's "hitting" for a couple seconds, then it probably isn't timing. It may run like crap with bad timing, but if it's hitting it's usually close enough to run.
    Completely guessing, if you're getting it to hit, you've verified compression, then you are running out of fuel. It takes very little air to get it to run (running is different than running well).
    Is it smoking at all when trying to start? Black smoke means too much fuel. White smoke (usually) means oil in the combustion chamber (water vapor can fool you as white smoke). If you aren't getting any smoke keep adding fuel until you get some (half joking). Pour some fuel in the Carb and try it (not a lot, like start with a 1/2 tablespoon).
    This is really an extreme choke. Add fuel. Remove air. Good for starting (not good for running).
    Ashford, CT
    Sounds like the carbs need to be cleaned to me.
    Clean the carbs.
    Lifer Stromper's Avatar
    Eastern Ct
    At least drain them
    check flow from the tank petcock
    get her running with starting fluid
    The calculus of hate
    Central VT
    Pilot jets and/or weak battery are where I'd start after draining the float bowls and gas tank and starting off with fresh fuel and 5 seconds of PRIME on the petcock.
    Jake
    2006 ZX-10R
    1999 Kawasaki ZRX1100
    Westford, MA
    Could be a vacuum leak. This has CV carbs, yes?
    Posting Freak FAST GSXR750's Avatar
    Granby Ct.
    Clean the carbs, I know my GS650 will not run without the air cleaner installed, just keeps sputtering out. Needs the restriction.
    GSXR750 GS650 Street Tracker
  1. This is the bike that started my obsession....
    By jwm2k3 in forum General Bike Related
    Last Post: 01-10-16, 05:58 PM
  2. Bike out of strorage, started up...now what?
    By Bluesman in forum Bike Maintenance
    Last Post: 05-04-03, 09:44 PM
  3. getting started
    By igneous in forum General Bike Related
    Last Post: 12-26-02, 01:49 PM
