Results 1 to 21 of 21
Help starting carbed bike...
    Senior Member JalopySiR's Avatar
    Dec 2008
    Charleston, SC
    Hey guys,
    My brother just picked up a 99' FZR600 for $200. It was sitting in a garage for a undetermined amount of time until the beginning of the winter, where it was left outside.
    It only has 5000 miles, but this poor thing has had a rough life.
    We removed the airbox, changed the oil/filter, dropped in a new battery, lubed the pistons with some PB blaster, put it in gear and forced the motor to turn over. Disconnected the fuel line to the carbs and drained what I could, and drained the line coming to the fuel pump. I put in some fresh gas, seafoam, and some octane booster. I also removed the muffler, as the midpipe was dented all to hell.
    Anyway, when I try to start it, it wants to catch. It will stumble and catch, then die. Usually with a spectacularly loud blast from the exhaust. There also appears to be some smoke, and sometimetimes popping coming out of the carbs when I'm cranking it over, not everytime, but...
    Anyway. I don't know diddly about carbs. Why won't this damn thing start? I can smell gas coming out of the carbs... I did move the "vacuum slides" manually, and turn the throttle alot. Could I have flooded it? Fouled my plugs?
    She wants to live again!!
    I know I'm a new guy, any help would be appreciated.
    Alex
    Lifer McBiggity's Avatar
    May 2003
    Charlton, MA
    Re: Help starting carbed bike...
    pull the carbs and give them a good cleaning.
    Posting Freak
    New Hampshire
    yeah clean the carbs and change the plugs
    KB KB's Avatar
    Manchester NH
    What Ryno said....................and put some ethanol approved stabil in the tank.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Dec 2008
    Charleston, SC
    Alright, this is gonna sound retarded. How does one go about cleaning the carbs?
    KB KB's Avatar
    Manchester NH
    Take it to a mechanic and pay.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Dec 2008
    Charleston, SC
    Just googled a bit, doesn't seem too bad. Thanks for the replies. I've been working on my own cars and bikes since I'm too cheap to pay people to do a half-assed job. I just haven't owned anything with this ancient technology called "carburetors"...
    Meriden, Ct
    Quote Originally Posted by JalopySiR View Post
    Then you are in for a treat...
    Pay someone...
    And follow KB's advise about the ethanol approved fuel stabilizer. Never leave un-stabilized fuel in the bike or you'll be cleaning carbs like it was your only purpose in life.
    See if you can find a service manual online. That would help you out tremendously.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    hahah we have one mechanic that it is his purpose in life..
    Posted by Jane in BoxChat
    Senior Member spydah's Avatar
    Fitchburg, MA
    Sounds like its junk. I'll give you your $200 back, come drop the bike off!
    LRRS #831 Novice
    2007 Ducati 1098 - Street (okay, sometimes track)
    2002 Suzuki sv650 - Pure track!
    2007 Suzuki sv650 - Next seasons track bike
    http://www.myspace.com/spydah77
    Old School Fool. ZX11D's Avatar
    Jan 2009
    Wilmington MA
    I looking at all the posts to your problem starting your bike. I`m an old gearhead from way back and I`m thinking it might be an electrical issue. Do you have sufficiant spark to the plugs. Coil working right. Could it be a timing issue? For a few bucks a guy with the tools and know how can diagnose this correctly. Pay someone dude.
    Dec 2008
    Charleston, SC
    Spark seems good. In theory it could be a timing issue, but it has been sitting for a long time with some old gas in it. I'll try cleaning the carbs, because even if it is another issue, it would need to be done anyway. It also appears that FZR600s have a problem with cupping intake valves, which also could be the problem, but the bike only has 5000 miles...
    Westford, Ma
    just clean the carbs GOOD. I mean take them apart, needles, jets, everything. CLEAN them good, run a wire through them not just compressed air. Make sure everything is spotless. Then try and start it again, synch the carbs and you should be golden. IF and that's a big IF it still runs shitty then think about what else it could be.
    Posting Freak 6 Fingered Man's Avatar
    Feb 2009
    Exeter NH
    drain the gas, drain the carbs, spray some starting fluid in the intake on the carbs while trying to start it, if it is a fuel issue it will start. If not look else where.
    KB KB's Avatar
    Manchester NH
    Maybe you should write yamaha a letter about the cupping valves and maybe you can get a recall on them. I hear the internet it the place for that sort of thing!!!
    Ok that was a joke. Now get the carbs off and get them to a shop and have them cleaned by a prfessional.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    If you'd rather not pay dealer prices to have those carbs serviced then PM me.
    Lots of little soft metal pieces in there. Any damage renders them junk.....and keep the parts sorted for the individual carbs during disassembly. Check for any rips in the rubber components.....the list goes on...
    Central VT
    Pilot jets.
    Jake
    2006 ZX-10R
    1999 Kawasaki ZRX1100
    Dec 2008
    Charleston, SC
    I really appreciate all the replies. As soon as he gets some time, my brother will get the carbs off and we'll take a look.
    Bergs, I may take you up on that offer.
    Thanks again for all the responses.
    Alex
    Dec 2008
    Charleston, SC
    Well, we got the carbs off...
    Then we got mentally prepared to get our hands dirty, and break them down...
    Unfortunately, the phillips heads screws were tightened down by Godzilla or Superman from the factory. Not wanting to strip em, or drill em' or work too hard before work, we finagled the float bowl drain bolts out, sprayed em out real good with carb cleaner, reinstalled em, and she fired up on the third try.
    After priming the fuel pump for a while...
    Now we need to fix the gigormous exhaust leak, anyone know a good exhaust shop in the Hadley, MA. area?
    Thanks again guys!
    Everybody to the limit!
    Winchester, MA
    I believe the float bowl screws are always loctited from the factory. Something about not leaking fuel onto a hot engine or something. Anyway, the best thing to do when you remove them the first time is to replace them with allen head bolts.
  1. Help me diagnose why my bike is not starting up
    By virtualbong in forum Bike Maintenance
    Last Post: 06-21-16, 03:21 PM
  2. Replies: 16
    Last Post: 09-21-15, 09:51 AM
  3. bike starting issues
    By black in forum General Bike Related
    Last Post: 05-18-06, 08:19 AM
  4. Issue with bike starting
    By Billy in forum General Bike Related
    Last Post: 03-07-06, 07:29 PM
  5. Trouble starting bike when warm..
    By Honclfibr in forum Bike Maintenance
    Last Post: 07-01-03, 10:14 AM
