Results 1 to 4 of 4
Carb help in Chelmsford
    Member FZR's Avatar
    Chelmsford, MA
    Having issues on my friends '87 CBR600, we yanked the carbs off and cleaned the jets only, after reassembling the bike isn't running smoothly anymore. Bogging on the throttle and just generally dying after giving it some gas. Anyone have any insight? The bike is fairly old so it's kinda a new experience for me, any help is greatly appreciated!
    Member Roland's Avatar
    Jul 2012
    Mashantucket Ct.
    Re: Carb help in Chelmsford
    Quote Originally Posted by FZR View Post
    I had a similar issue fixing a buddies carbs on an 95 gxr it turned out his float bowl was going and the cab cleaner i sprained finished ruining it. I would suggest taking the carbs back out and giving them a thorough look over. Make sure nothing got unseated when you worked on them. And make sure you properly adjust the fuel to air mixture ratio. Maybe not your issue, but thats not a bad place to start.
    Jan 2009
    Waltham
    Did you sync the carbs when you were done? You need to do that if you even look at the carbs on most bikes. My thoughts are someone might have turned a fuel mixture screw by accident?
    Member FZR's Avatar
    Chelmsford, MA
    ah yea, i need to get a sync tool, but I think the problem was we had too many hands working on a small part without coordinating with each other, someone messed with the idle air screws. Problem should be sorted out by tonight! thanks for the insight guys
  1. Hello from Chelmsford, MA
    By JackFrost in forum Welcome and Intro
    Last Post: 06-01-14, 07:06 AM
  2. tire changing near chelmsford MA
    By r1dermon in forum Bike Maintenance
    Last Post: 04-03-14, 03:48 PM
  3. Biker Down, Chelmsford (seems to be ok)
    By gadget in forum General Bike Related
    Last Post: 06-07-11, 12:52 PM
  4. New Guy from Chelmsford, MA
    By Maple50175 in forum Welcome and Intro
    Last Post: 05-13-11, 04:35 PM
  5. kz440 Carb Headache! need CARB GURUS!
    By Bandit12k in forum Bike Maintenance
    Last Post: 05-01-08, 12:44 PM
