Ok, lets hear from the masses.
Its an 01 RC 51 (hydraulic Clutch). Lately I've been feeling surging in traffic when I'm going slow (1st Gear mostly). Today I put it up on the stands to clean it and figured I would check the chain for tension.
When I run it (let the wheel spin an 1st gear) the chain visibly jumps every 5-10 seconds, it seems to go away when I speed it up (keep in mind the rear wheel is up on the stand and I'm sitting watching it). When this happens you can hear a "clunk"
I checked the chain tension and we are good at all points.
There is no binding of any sort (actually this is a brand new DID chain I put on last fall before I stored the bike for the winter)
I checked the front sprocket thinking it might be warped or loose but we are good there too.
Now I am thinking the "clunk" is similar enough to when you drop into 1st gear from neutral that maybe its the clutch and the bike is jumping gear.
Final thought - it cant be oil as I am running motorcycle specific Mobil1.
Does this sound like I need a new clutch?
Feedback appreciated.
