Results 1 to 25 of 28
F4i Racebike help
    F4i Racebike help
    Here is the deal, Both me and my Friend race 2002 Honda F4I's We both had lowsides over the weekend (left side)
    Now both Bikes wont start, The power goes on the Fuel injection does its thing only the starter wont spin. First it clicks and if you hold the starter button it whines and the Indicator lights dim. You feel with your hand the starter trying to Spin and it gots really hot.
    Two Bikes Same problem Exactly
    Any Ideas?
    Just Registered
    Mar 2003
    Shrewsbury, MA
    F4i Racebike help
    Paging Degsy...
    man know's everything about F4i's..
    F4i Racebike help
    i'll throw my bet into the ring.... tip-over sensor?
    Jun 2005
    If it had been the Bank Angle Sensor, it would have corrected itself the next time they put the key in and tried starting it. Also, I dont think there would even be a click noise occurring when pushing the starter if it had been the Bank Angle Sensor. There wouldnt be any noise.. Curious..
    Northshore/Beverly, MA
    F4i Racebike help
    Quote Originally Posted by FireFly View Post
    Pull the plugs and drain the oil or gas that wept into the cylinders...
    or side cover is jamming flywheel (bent)
    F4i Racebike help
    Thank You For your imput? I will check these out today
    And
    Degsy Has been Contacted
    F4i Racebike help
    Quote Originally Posted by Mongoose441 View Post
    And
    Ooh, it's terminal. Luckily I have a race motor ready to install for you.
    Sounds like hydrolock, but suspicious that it's on BOTH bikes.
    If the starter motor is getting hot, remove the plugs (like Mark says) and turn the motor over. Keep your face away from the spark plug holes. More likely oil in the cylinders than gas.
    If it isn't hydrolocked, remove all the 8mm bolts from the stator cover and check the starter sprag gear (top right hand side). It might have become dislodged and not be engaging the flywheel.
    Degs
    Posting Freak senecak19's Avatar
    Massachusetts
    F4i Racebike help
    One of those wasn't hit by say a red GSXR by chance was it? If so that was me... Chassis wise I think I'm okay. Plastic wise, I'm a mess.
    I should have something together for this coming weekend. Good luck with the bikes.
    F4i Racebike help
    [QUOTE=senecak19;361463]One of those wasn't hit by say a red GSXR by chance was it? If so that was me... Chassis wise I think I'm okay. Plastic wise, I'm a mess.
    Nope we did not need any help Crashing, Pittenger5 (505) Had a faulty Break Lever that caused his brakes to lock up in practice (first 1/2 Lap)
    I (441) lowsided In 11 (on the downshift) in the rain in heavyweight SB
    By hook or by crook I will be there For Friday Practice
    Massachusetts
    F4i Racebike help
    Nice... my thoughts exactly... "Hooks or crooks"! I won't make Friday practice as I have to start a new job, but I'll be there Friday night! See ya then!
    Lifer Punjistick's Avatar
    Norwell, MA
    F4i Racebike help
    I don't know how the honda tip-over sensors work but I know my old gsxr used a U-shaped piece of metal with a ring in the center of the 'U'. When the bike was tipped over, the ring would slide and open or close the switch (I don't know which). The problem was though that sometimes the ring would get stuck to one side and people had problems getting the bike to start.
    Is there a way to see if the bike is throwing a fault code. c23 was the code that pointed to the TOS for the gsxr.
    636cc's of fury. 06ZX6R's Avatar
    Sep 2006
    Pembroke, Ma.
    F4i Racebike help
    Im with firefly on this one, if it was the bank angle, your starter shouldnt be getting hot or trying to spin.
    -alex
    F4i Racebike help
    Hydrolock It seems Will be sure Tomorrow, From doing a search on Google Hydrolock is fairly common on F4is that fall over, And the stunters even have a mod for this. Pittengers bike Was on its side for about 7 Minutes, AND MY bike was completely upsidedown sliding in the grass at turn 11.
    If not anybody selling a good racebike Fully preped
    441
    F4i Racebike help
    All Fixed Both Bikes Hydrolock with oil.
    See you at friday practice
    F4i Racebike help
    Sweet!!
    BTW, it couldn't be gas. Fuel injectors don't leak.
    derek
    F4i Racebike help
    I guess you really have move out of the way when the oil clears from the cylinder, I still have Motul in my haiR
    Thanks again guys
    DC
    F4i Racebike help
    Sweet!!
    derek
    Well, all I said was oil OR gas...just in haste of writing! I knew that!
    How ya been Degs?
    Lifer Pittenger5's Avatar
    Austin
    F4i Racebike help
    And one thing we learned, if your bike is hydrolocked, dont clear the cylinders on your parents driveway. Leaves a lovely pattern.
    Zip Tie Alley #505
    Norwell, MA
    F4i Racebike help
    can't you place a rag or something over the holes so it doesn't spray everywhere?
    F4i Racebike help
    Thanks again guys
    DC
    erm, did I not tell you that...specifically....about 3 times?? Sheesh, kids these days, never listen, LOL
    BTW Daniel, you're wheel is ready. They had a bitch of a time, broke a tool, had to helicoil both of them. $60 total. More than I thought, but not much considering the work they put in.
    degs
    F4i Racebike help
    How ya been Degs?
    Heh heh, have to get my knocks in when I can. You don't slip up often mark.
    Oh, usual, busy busy. Teaching MSF next weekend so I can't get to the track like I wanted, dammit. Maybe next race weekend.
    F4i Racebike help
    Yup, will have to knock elbows soon!
    F4i Racebike help
    Yup, will have to knock boots soon!
    F4i Racebike help
    Cool thanks for your help, Maybe one of these racer types can bring it up to loudon for me.
    Let me know
    Degs
    (i will get a check out to you Tommorow)
    ...inside the van. loudog's Avatar
    Central, MA
    F4i Racebike help
    Does the it sound like the starter is engaging with the engine?
    I don't know too much about motorcycle starter systems, but if it's anything like cars it maybe that the pinion solenoid in the starter died.
    So, the starter is just spinning the pinion gear but it's not connecting up with anything.
    Can you feel the engine trying to turn over or is it just a weak whining noise when you try to start it?
    Retired LRRS/CCS EX #212 | Woodcraft | Armour Bodies | Dainese USA |
  1. 05 R6 racebike
    By sdog30 in forum For Sale
    Last Post: 04-23-13, 10:50 PM
  2. GEN 1 SV Racebike
    Last Post: 11-13-12, 12:34 PM
  3. wtb racebike
    By freeskier in forum Wanted
    Last Post: 09-06-12, 12:08 PM
  4. WTB: 600 racebike
    By GixerJockey in forum Wanted
    Last Post: 07-24-12, 09:39 AM
  5. 2nd Gen SV racebike
    By Major in forum For Sale
    Last Post: 05-05-08, 10:45 AM
