Results 1 to 25 of 26
pair valve
    Senior Member double agent's Avatar
    Sep 2002
    acushnet - yates replica
    pair valve
    does anyone know If you can get a pair vavle block off for a 01gsxr600 and if so what is the web site. I can only find them for a busa
    If money is the root of all evil,
    why do churches beg for it?
    Lifer GMAN226's Avatar
    Coventry RI
    pair valve
    EBAY...
    Gerard
    pair valve
    a bolt and a zip tie?
    i dont know ive never seen one
    Member alfred's Avatar
    Jul 2002
    Manchester
    pair valve
    I used the bolt and Zip tie on my TL1000R. It has held for almost 8yrs now.
    Mar 2004
    woonsocket ri
    pair valve
    1. make your own. get some gasket meterial and have a machine shop cut out the shape you need.
    2. All you really need to do is plug the hoses that come off the engine and take the pair valve off.
    The Busa pair valve plates also fit the SV
    Sep 2002
    pair valve
    Im going to try it , if I like it , It will stay
    Apr 2004
    chicopee
    pair valve
    look up the pair sucker mod. Basically you replace the large hose that goes to your airbox with a fuel hose(they are stronger and won't collapse). You re-route it to your crank case breather and cap off the airbox. This will create a crackcase sucker pump. It evacuates the pressure inside your motor and has been shown to pick up 2 to 4RWHP on a Hayabusa. Not a lot but it's basically free and not only will your not have to block off your PAIR valve but now you've just gained something in the process.
    Lifer Punjistick's Avatar
    Norwell, MA
    pair valve
    what's a pair valve? I assume it has something to do with emissions and removing it makes more power?
    Mar 2004
    woonsocket ri
    pair valve
    "What is the PAIR valve you ask? It's part of the Emissions system on the bike. It injects air into the exhaust ports to burn off the un-burnt fuel. You really won't gain Horsepower from doing this (some do claim 1-2hp gains though). It's not heavy so no real weight loss either. I was gonig to get the bike put on a Dyno and tuned the next tuesday so I figured I'd remove this before then. Either you remove it, or clamp the hoses when you get it tuned on a dyno. Otherwise the air injection will throw off the A/F reading on the Dyno and the bike won't be tuned correctly. Also by removing the valve the bike feels alittle smoother, no popping on deceleration anymore. If you are bored, go ahead and remove it, or if you plan on having your powercommander tuned on a dyno. Otherwise it really didn't make much of a diffrence."
    Apr 2004
    chicopee
    pair valve
    Not removing it and running a full system can cause the bike to run lean though because more air is being injected into the motor.
    Norwell, MA
    pair valve
    Interesting. I googled it myself last night right after I posted. Most people seemed to notice popping on deceleration with it removed. Many claimed it did absolutely nothing and once it was put back in the popping instantly stopped. So I duno must be one of those try it for yourself and see type things.
    I do have a full system on my bike now and don't notice any popping. One of these days I might take it out and see what happens.
    Apr 2004
    chicopee
    pair valve
    maybe it's just on a Hayabusa that it needs to be removed then, but I would think it would be the same for all bikes.
    Northshore/Beverly, MA
    pair valve
    Quote Originally Posted by busa413 View Post
    The Pair injects air AFTER the exhaust valves...has nothing to do about a lean run. It also doesn't increase horsepower. reason for removing, and blocking off, is to stop 6 foot flames from shooting out of your aftermarket pipe, and quell the popping.
    Apr 2004
    chicopee
    pair valve
    I always thought that was what the flames were from.
    It can be used to make more horsepower though by re-routing the hoses and replacing the air hose with fuel hose and making a crankcase evacuation pump. Granted it's only 2 to 4RWHP but it'll only cost you about $3.00
    Central VT
    pair valve
    Flames are cool!!!!!
    Jake
    2006 ZX-10R
    1999 Kawasaki ZRX1100
    May 2005
    Bernardston, MA
    pair valve
    I'd rather have the flames. Flames are fricking sweet. And backfiring just lets everyone know you mean business.
    Lifer smf's Avatar
    Nov 2006
    pair valve
    Quote Originally Posted by JeffL View Post
    Scott
    Lifer union's Avatar
    Blackstone, MA
    pair valve
    Quote Originally Posted by smf View Post
    I find it quite annoying on my bike. Its loud enough without the shotgun blasts coming from it under deceleration. I intend on removing my pair system this winter. I have a set of block off plates all ready to go.
    James
    pair valve
    Actually, the system really doen't evacuate the amount needed to fully put the crankcase into a vacuum....If you saw the kind of pumps they use on pro stock bikes, or the mini superchargers on formula one engines, will make you take another look at it.
    Blackstone, MA
    pair valve
    Ok this isnt "my bike" but its the same bike with the same set up as mine. Its a dyno run with the pair valve still on the bike. It might look cool but its god damn annoying after a while to get the popping on deceleration.
    Video - 2005 HONDA RC-51 DYNO W/ SATO BANZAI'S SOUNDS LIKE THUNDER!!!
    James
    Oct 2003
    Worcester MA
    pair valve
    James...you want to get in touch with Guru Lou...He's a fuckin wiz with an RC51 on his dyno...soon as the weather breaks we'll take a ride up to his place . He's also very cool to talk to...he's so genuinely ( Bushism? ) nice you notice I NEVER bust his balls on ROGUE...
    Blackstone, MA
    pair valve
    Quote Originally Posted by old timer View Post
    Sounds good. Ive talked to him a couple of times about a few things. Like the rest of the people on Rogue he seems like a good guy. You just need to get out of MA and down toe AL to see for yourself
    James
    Oct 2003
    Worcester MA
    pair valve
    If I show up at Barber it'll turn into that camping trip in Deliverence...Too many of them inbred hillbilly's are looking for revenge on my liberal yankee ass...
    Blackstone, MA
    pair valve
    Im not going this year I wish I was I had a good time last year. Next year plan on going.
    James
    Oct 2003
    Worcester MA
    pair valve
    Girlfriend wont let you...?
  1. PAIR mod on the GSX-R
    By Jim in forum Bike Maintenance
    Last Post: 01-29-13, 04:01 PM
  2. Red sox pair for Sunday vs laa
    By Manny in forum For Sale
    Last Post: 10-10-09, 12:41 PM
  3. RED SOX pair - WED NIGHT
    Last Post: 07-08-09, 11:08 AM
  4. Pair of old 50's... $450
    By oreo_n2 in forum For Sale
    Last Post: 02-24-08, 08:26 PM
  5. need a pair of gloves
    Last Post: 05-02-07, 12:44 PM
