Results 1 to 5 of 5
Clutch bleeding ques.
    Walpole
    After I change the fluid in my clutch it seems like it takes no time at all to grunge up again. Am I not bleeding them properly? I am doing it like a set of brakes, is this the correct way? Or is this normal? All of my older bikes had a cable this is a new one for me.
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    You're clutch fluid will darken quicker than the break fluid, 'cuz it gets much more use. However, darkness can also be a sign of moisture in the system too. If you're concerned about it, I'd say replace the fluid all together making sure ALL the old fluid has been completely bled through....
    [Edited on 9/3/01 by Stoneman]
    Wakefield, MA
    Also make sure that the system is air tight. Like all the gaskets of whatever is there are not letting the air/moisture through. That would cause the fluid to break down.
    Eugene '99 EX 500R
    Wakefield, MA
    Actually, the moisture is a natural occurance from the constant heating & cooling of the fluid. Some moisture will always end up existing in the system, and as long as the fluid doesn't become too diluted it shouldn't hamper performance....
    They are made though, to be airtight. The tiniest amount of air in there could seriously degrade your system's abilities to function at it's full capacity......
    Walpole
    Thanks for the info.
    Ed
    2000 Ducati 900ss
  1. For Sale - Parts & Tools | Yoyodyne slipper clutch, Ducati 848 wet clutch
    By jwm2k3 in forum For Sale
    Last Post: 04-27-17, 10:07 AM
  2. Brake Bleeding/Bleeding Alternative Help?
    By "Dangerous" Dan K in forum Bike Maintenance
    Last Post: 06-11-09, 12:30 AM
  3. dual carb ques?
    By wingerdor in forum Bike Maintenance
    Last Post: 07-25-08, 08:41 PM
  4. front end ques.
    By double agent in forum Bike Maintenance
    Last Post: 07-26-06, 04:48 PM
  5. More tire Ques.
    By PinHead in forum General Bike Related
    Last Post: 04-09-02, 08:46 PM
