The carb on my son's XR100 was gummed up and the bike wasn't running well, so I took the carb apart and cleaned the jets up with carb cleaner. This was the first time I 've ever taken a carb apart, and it looks like a very simple carb. After re-assembly, the overflow started pissing gas. The floats seem to be work OK with the bowl off, so I'm not sure why it's leaking. I'm assuming the float bowl gasket is OK because it wasn't leaking before I took it apart. What else should I check for the source of the leak?
