The CARRILLO connecting rod is a precision, high strength, quality connecting rod, which when properly installed and
maintained, will perform flawlessly in today’s racing and high performance internal combustion engines. We would like
to offer some suggestions and specifications that should be helpful in your installation.
All bolts should be lubricated under the heads as well as
on the threads. We recommend the
bolt lube included, or
as an alternative, molybdendum base paste mixed with
engine oil.
A preferred method to torque the bolt is by using the
stretch figure listed in the table below. In order to check
bolt stretch, simply fixture one rod, leaving the cap portion
free from clamping load. Measure both bolt lengths loose,
and then progressively tighten the bolt until the measured
increase in length correlates with the figures below. Use
the indicated torque reading to tighten all the connecting
rods in final assembly.
