Results 1 to 25 of 29
cbr600 f4 won't start
    Apr 2013
    The bike ran perfectly when I got it, but now it won't start and I smell fuel, bike is injected, any ideas?
    Banned G21forme's Avatar
    Lakes
    Re: cbr600 f4 won't start
    Bad gas, water in the tank, did you have it on a tender? I'm guessing it's been in cold storage all winter?
    Apr 2013
    The gas is good, it actually just ran fine the day before yesterday. I should have specified that I just got it.
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    What year?
    Wirelessly posted
    F4i.
    Any fi light blinking?
    Does it turn and it doesn't fire up? Does it not turn at all. You gotta be more specific man. Do lights work?
    Apr 2013
    It's a 2000, no warning lights are on of any kind. It just stopped starting.
    Apr 2013
    Sorry, it's firing, I get a putt putt out of it then nothing. Everything seems to be working fine it seems, it just won't start.
    Mar 2012
    Chichester, NH
    2000 is not fuel injected. It is carbureted.
    This is important. Trouble shooting fi vs carbs are very different.
    Apr 2013
    This bike is injected, whether there was a mix up in paper work with the dmv or not I don't know, but it is very much fuel injected. I'm thinking a motor swap was done, guy wasn't real specific. At any rate, I appreciate all the help.
    still a newbie j4eric's Avatar
    Aug 2009
    Grafton, MA
    What made you say it's fuel injected?
    08 CBR 1000RR street bike
    99 R6 track bike
    02 F4i sold to a nesr member
    oh man its gonna be on those topics... where is clayton when we need him the most?
    Aug 2009
    Grafton, MA
    It won't hurt...FI or not......hold the throttle wide open and push the start button.....make sure the engine switch is on position
    99 R6 track bike
    Are you certain the battery is charged? The F4i will turn the starter but won't fire if voltage is down.
    If the battery is good, I believe there is a tip-over sensor in the nose. Might wanna investigate there.
    Another thought that crossed my mind was, it just came out of storage (?), check over the electrical for mice damage.
    As far as a motor swap, that bike would need a tank, air box, complete electronics package to support FI, throttle bodies...and those items are just the beginning. Gauge cluster between the F4 and F4i would be tricky but doable. I have my doubts that the engine was swapped to the injected version.
    Apr 2013
    Because it has fuel injectors. I'll try that though, otherwise maybe I should clean everything out.
    Mar 2012
    Chichester, NH
    Can you take a picture of the injectors?
    Apr 2013
    Sorry everyone, a friend of mine has been writing everything including that it was injected, like an idiot. The bike is carb. I've been messing with it this entire time including checking sensors, gas, carbs, I killed the battery trying to start the damn thing, so after a quick charge I'll be at it again. Should I use starting fluid at all?
    Lifer snwbrdr435's Avatar
    Middle of Nowhere
    Quote Originally Posted by Nixsus View Post
    th
    My friend just got these weird crab things from having sex with my neighbors monkey how can he get rid of them?
    Apr 2013
    Something like that. Thanks for your input.
    Quote Originally Posted by snwbrdr435 View Post
    th
    Starting fluid. Unless the monkey was fuel injected, then it would be different.
    Aug 2009
    Grafton, MA
    Haha...no, just try what I told you and make sure the battery is all juiced up
    99 R6 track bike
    Apr 2013
    I will, thank you.
    Mar 2012
    Chichester, NH
    What is the choke set at?
    Is the fuel switch on? (It's hidden under the tank).
    A motor needs 3 things to start. Fuel, air, spark. With a carbureted bike the most obvious suspect is fuel.
    Natick
    Wirelessly posted
    I just brought out my 900rr from hibernation... I had a boat load of issues,but it turned out to be a weak charge on the battery even though my tender read full. I had issued even starting it with a car battery attached, but 15 minutes of charging it on my running car, I disconnected it and the bike fired up.
    Apr 2013
    The choke and everything is fine, like I said, it was starting just fine one minute, and not the next, what's the elevation change to require a re jet?
  1. For Sale - Motorcycles | 2002 CBR600 F4i $3,250
    By MikeP in forum For Sale
    Last Post: 05-26-17, 04:35 PM
  2. For Sale - Motorcycles | 03 CBR600 F4i track bike
    By Damnut in forum For Sale
    Last Post: 03-18-14, 12:40 PM
  3. WTB cbr600 F2 rearsets
    By ecd2004 in forum Wanted
    Last Post: 11-08-11, 11:07 PM
  4. NH: CBR600 F4 parts (not F4i)
    Last Post: 10-18-11, 07:17 PM
  5. 2004 CBR600 F4i
    By rhy in forum For Sale
    Last Post: 10-08-10, 08:20 AM
