Results 1 to 20 of 20
Chain
    Lifer Pittenger5's Avatar
    Austin
    Chain
    What chains do you guys use on the 600 race bikes.
    Zip Tie Alley #505
    Re: Chain
    Link style o-ring.
    2016 BMW S1000XR
    Re: Chain
    I disagree. O-rings slow you down. But since I've only got a 650, I can tell you with confidence I use an EK MVXZ 520. It is a quality chain for reasonable money.
    Re: Chain
    Actually, dyno time shows o-ring chains, while measurably heavier have less friction losses than non o-ring putting more power to the ground.
    Austin
    Re: Chain
    I don't give a rats ass about the 1/4 horsepower I'm gaining/losing with an o-ring. Just want something solid that will work well.
    Zip Tie Alley #505
    Re: Chain
    Spend more than $12 on a 520 'blah'-ring of some type chain. Clean it with WD40 frequently, lube it if you desire, watch the slack and replace when it starts needing frequent adjustments.
    Re: Chain
    DID ERV3. If you want the best.
    Austin
    Re: Chain
    So when you replace the chain, do you put the chain adjusters all the way to the front, or is it good to leave a little space for adjustment? (Not sure why you'd have to adjust forward)
    Zip Tie Alley #505
    Re: Chain
    DID 520 ERV3 chain. That's all you ever get. It comes with a rivet master link.
    Don't clean it with WD40....ever.
    Use kerosene or a chain cleaning product.
    Install the chain around the middle of the adjustment blocks, so you can go up/down sprockets for different gearing at different tracks.
    Posting Freak Tas's Avatar
    Sep 2013
    Jaffrey NH
    Re: Chain
    I got this advice from a guy who is damn fast on his SV at LRRS. I think he changed his number this year. If it holds up to the way he pushes it then it should be more than enough for me.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    Re: Chain
    For the record, when I suggest cleaning the chain with WD40, I don't mean taking the chain off and soaking it over night. A rag loaded with a little WD40 used to wipe down the chain should be plenty and won't harm the o-rings at all. For anything more serious I have a steam cleaner that works right on the bike.
    Re: Chain
    This
    Re: Chain
    If anybody should need a rivet master link for DID ERV3 in a 520 size for FREE, I have 3 extra. Alas, I have no DID ERV3 chain, because she is 'spensive!
    Sep 2013
    Jaffrey NH
    Re: Chain
    Hi,
    I wouldn't mind having a spare just in case. I'll be at the classic or however you'd like me to get it.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    Re: Chain
    That would be the most efficacious form of conveyance. Come find me, Center garage 15 #613 Doug Cooke.
    Sep 2013
    Jaffrey NH
    Re: Chain
    Will do, Thanks Doug!
    Todd
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    Re: Chain
    Wish I had known this. I just bought 3 links.
    Re: Chain
    I use a D.I.D 520ERV3 on my RSV1000R. If it can hold up to the torque that that bike can out out, it's MORE than enough for a 600cc I4.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Re: Chain
    O-ring 520; never had to replace them, LOTS of laps.
    May have one sitting here for you richie
    Austin
    Re: Chain
    Got one already Kitt, thanks though.
    Zip Tie Alley #505
  1. RK chain
    By MysteriousR1 in forum General Bike Related
    Last Post: 03-06-10, 09:39 PM
  2. WTB:525 chain
    By duganc1717 in forum For Sale
    Last Post: 09-12-09, 07:20 PM
  3. Replies: 0
    Last Post: 05-03-07, 12:51 PM
    Last Post: 06-29-04, 12:23 AM
    Last Post: 05-28-03, 09:17 PM
