Results 1 to 21 of 21
chain lube
    Corner Vagina roso's Avatar
    Apr 2006
    ayer ma
    chain lube
    so today i cleaned and lubed my chain for the first time ever
    i have 600 mi on the bike and did the cleaning and lube i have never done it before so here is the dumb question
    how do i know if i have enough lube on the chain
    and if not what can happen to it
    thanks in advance and sorry for being such a newb
    Jun 2005
    more info...
    what kind of chain and what kind of lube are you using?
    Mar 2004
    woonsocket ri
    Re: more info...
    You can't even answer without asking a question
    Here is a good rule, If you have to ask it isn't enough.
    Coat the chain and your done. Later do it again. Keep it lubed it it will last longer.
    Jun 2005
    knowledge is Power
    what if he was using a lube that required the chain to be warm inorder to stick to the chain and not fly off when he rode it(ie Honda lube).? Is it an o-ring chain?Is he using chain wax or lube?
    Just trying to give good advice. Am I wrong??
    Apr 2006
    ayer ma
    chain lube
    i think it is a regular o ring chain and it is maxima lube in the areosol can
    how long will a chain last and what do they cost to replace
    Nov 2004
    Boston, MA
    chain lube
    I dont know much, but I know that when I first lubed my chain, I used way too much, and I didn't do it when the chain was warm - result was chain lube sprayed right up the sidewall of my rear tire - no joke, right up the side like 2 inches. (wasnt a problem cause I never leaned the bike over anyhow, but it could have been).
    The basic way to do it is.
    Go for a ride, get the bike up on a rear stand, and spray it. Try your best to spray directly at the chain, as opposed to at an angle when it can get all over other parts.
    Mar 2004
    woonsocket ri
    Re: knowledge is Power
    See what I mean, More questions
    I ass u me d he read the can first. Did you read the can first?
    Apr 2006
    ayer ma
    Re: Re: knowledge is Power
    no i just grabbed the first areosol can in the house i thin it said PAM
    yes it said the chain should be warm but i had to clean the chain first so i think by the time igot to lubing it was cooled down
    if it dries out today i will go for a short burst and re lube
    thanks for the help
    Mar 2004
    woonsocket ri
    Re: Re: Re: knowledge is Power
    See there's the problem. Pam is not a lubricant. It makes stuff NOT stick. If your quick you can cook lunch on your chain when you stop riding
    FUCK OFF Hardcore's Avatar
    Jul 2005
    norwood ma
    no not wrong----just an idiot !
    Jul 2005
    norwood ma
    chain lube
    Originally posted by Manny
    I dont know much,
    aint that the truth !
    chain lube
    I use ATF
    Jul 2005
    norwood ma
    Re: chain lube
    I am a chain specialist + actually, the correct way to lube ANY chain is:
    1)warm up chain by either riding bike OR using a propane only torch
    2)empty the entire contents of the can onto chain evenly
    3)wait 5 minutes (to soak in + excess to drip off)
    4)completely dry the chain lube using a haidryer set on the medium warm (not hot) setting
    5)let bike sit for 6 hours
    6)immediately ride bike for 100 miles (no more no less)
    7)let bike sit for another 6 hours
    8)repeat the above process
    this process MUST be done exactly like stated above OR the chain May explode
    chain lube
    clean and lube your chain with wd40 before every ride and it should look nice and last for 25k miles
    KB KB's Avatar
    Manchester NH
    I have some advice: KILL YOURSELF!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    KB KB's Avatar
    Manchester NH
    chain lube
    I will add some usefull chain lube tips to this thread.
    Clean the chain with Kerosene not Wd-40. Wd-40 is a solvent that over time will detiorate o and x rings.
    Clean the fuck out of it with a stiff bristle brush and some kerosene. The hit the chain with some simple green or that purple degreaser or whatever the fak it is.
    Put the thing up on a stand start it up and put it in gear. Hose the crap out of the chain till it rinses clean and all the gunk will be off of it.
    Get out your air compressor and run the bike in gear again and blow all the water and gunk out of the chain.
    Now when you lube the chain make sure you lube the INSIDE of the chain where it actually touches the sprockets. Take her for a spin and warm up the chain.
    Lube it again when you get back then adjust it.
    Viola all done.
    Most important is to lube the INSIDE of the chain. You see these guys lubing the back of the chain behind the rear sprocket. last i knew the sprockets contaced the chain on the inside. hence where the lube should go.
    Good luck.
    BTW if you loose a finger with this method I am not liable!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Apr 2006
    ayer ma
    chain lube
    thanks this is pretty much what i did minus the compressor and stand
    I dont think i will use wd40 i hear too many mixed things about it
    thanks for the help
    and should i be emptying the can onto the chain or just coat it
    Viola all done.
    Good luck.
    Dec 2003
    Ma
    chain lube
    I always tell KB he's a moron for putting his bike on the stand and running it in gear. First thing that's going to happen is he's going to lose three fingers fucking with the chain, second thing that's going to happen is the bike is going to fall off those cheap walmart stands and rocket into traffic.
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    chain lube
    i dont care what anyone says... when you're bike is orange and your rims are polished... all chain lubes FLING GUNK all over the place!!!!
    one day i am gonna make the switch back to non o-ring chains and go back to using motor oil for lube.
    Brent LRRS #772
    2006 KTM 560 SMR
    chain lube
    I tried using motor oil, it's a bitch to clean, even worse than chain lube
    chain lube
    if you use the bel-ray super clean lube you can SEE how much is on there
  1. Best chain lube?
    By Tekime in forum Bike Maintenance
    Last Post: 09-05-18, 09:23 AM
  2. Chain lube
    Last Post: 11-08-08, 12:16 AM
  3. Chain lube?
    By zxme in forum Bike Maintenance
    Last Post: 05-08-07, 10:10 PM
  4. Chain lube
    By NHBusa in forum General Bike Related
    Last Post: 05-19-04, 10:16 AM
    Last Post: 05-28-03, 09:17 PM
