so today i cleaned and lubed my chain for the first time ever
i have 600 mi on the bike and did the cleaning and lube i have never done it before so here is the dumb question
how do i know if i have enough lube on the chain
and if not what can happen to it
thanks in advance and sorry for being such a newb
what kind of chain and what kind of lube are you using?
You can't even answer without asking a questionOriginally posted by FireFly
what kind of chain and what kind of lube are you using?![]()
Here is a good rule, If you have to ask it isn't enough.
Coat the chain and your done. Later do it again. Keep it lubed it it will last longer.
what if he was using a lube that required the chain to be warm inorder to stick to the chain and not fly off when he rode it(ie Honda lube).? Is it an o-ring chain?Is he using chain wax or lube?
Just trying to give good advice. Am I wrong??
i think it is a regular o ring chain and it is maxima lube in the areosol can
how long will a chain last and what do they cost to replace
I dont know much, but I know that when I first lubed my chain, I used way too much, and I didn't do it when the chain was warm - result was chain lube sprayed right up the sidewall of my rear tire - no joke, right up the side like 2 inches. (wasnt a problem cause I never leaned the bike over anyhow, but it could have been).
The basic way to do it is.
Go for a ride, get the bike up on a rear stand, and spray it. Try your best to spray directly at the chain, as opposed to at an angle when it can get all over other parts.
See what I mean, More questionsOriginally posted by FireFly
Just trying to give good advice. Am I wrong??![]()
I ass u me d he read the can first. Did you read the can first?
no i just grabbed the first areosol can in the house i thin it said PAMOriginally posted by dhuze
See what I mean, More questions![]()
yes it said the chain should be warm but i had to clean the chain first so i think by the time igot to lubing it was cooled down
if it dries out today i will go for a short burst and re lube
thanks for the help
See there's the problem. Pam is not a lubricant. It makes stuff NOT stick. If your quick you can cook lunch on your chain when you stop ridingOriginally posted by roso
no not wrong----just an idiot !Originally posted by FireFly
Originally posted by Manny
I dont know much,
aint that the truth !
I use ATF
I am a chain specialist + actually, the correct way to lube ANY chain is:Originally posted by roso
1)warm up chain by either riding bike OR using a propane only torch
2)empty the entire contents of the can onto chain evenly
3)wait 5 minutes (to soak in + excess to drip off)
4)completely dry the chain lube using a haidryer set on the medium warm (not hot) setting
5)let bike sit for 6 hours
6)immediately ride bike for 100 miles (no more no less)
7)let bike sit for another 6 hours
8)repeat the above process
this process MUST be done exactly like stated above OR the chain May explode
clean and lube your chain with wd40 before every ride and it should look nice and last for 25k miles![]()
I have some advice: KILL YOURSELF!
I will add some usefull chain lube tips to this thread.
Clean the chain with Kerosene not Wd-40. Wd-40 is a solvent that over time will detiorate o and x rings.
Clean the fuck out of it with a stiff bristle brush and some kerosene. The hit the chain with some simple green or that purple degreaser or whatever the fak it is.
Put the thing up on a stand start it up and put it in gear. Hose the crap out of the chain till it rinses clean and all the gunk will be off of it.
Get out your air compressor and run the bike in gear again and blow all the water and gunk out of the chain.
Now when you lube the chain make sure you lube the INSIDE of the chain where it actually touches the sprockets. Take her for a spin and warm up the chain.
Lube it again when you get back then adjust it.
Viola all done.
Most important is to lube the INSIDE of the chain. You see these guys lubing the back of the chain behind the rear sprocket. last i knew the sprockets contaced the chain on the inside. hence where the lube should go.
Good luck.
BTW if you loose a finger with this method I am not liable!
thanks this is pretty much what i did minus the compressor and stand
I dont think i will use wd40 i hear too many mixed things about it
thanks for the help
and should i be emptying the can onto the chain or just coat itOriginally posted by rmbbikes
Viola all done.
Good luck.
I always tell KB he's a moron for putting his bike on the stand and running it in gear. First thing that's going to happen is he's going to lose three fingers fucking with the chain, second thing that's going to happen is the bike is going to fall off those cheap walmart stands and rocket into traffic.
i dont care what anyone says... when you're bike is orange and your rims are polished... all chain lubes FLING GUNK all over the place!!!!
one day i am gonna make the switch back to non o-ring chains and go back to using motor oil for lube.
Brent LRRS #772
2006 KTM 560 SMR
I tried using motor oil, it's a bitch to clean, even worse than chain lubeOriginally posted by oreo_n2
one day i am gonna make the switch back to non o-ring chains and go back to using motor oil for lube.![]()
if you use the bel-ray super clean lube you can SEE how much is on there
