OK- Here is my problem..
I have intermittant turn signal issues. Today while riding the turn signals stopped working. I would have to hold down the toggle in the center position(cancel position) for about 3 seconds then they would work again!!
after about 20 miles more only the right side signals would work. If I tried to put the left signal on it wouldnt work and the right side wouldnt work either unless I pushed the toggle switch in for 2-3 seconds again
I got home and the bike sat for 2 hours, I went back out and now the blinkers work just fine- both sides!! I took apart the actual turn signal assembly and it appeared mechanically fine.
Is this a flasher issue? Maybe it is overheating??
